Pair 3, 4 Short or Abnormal Termination
lacibaci
Has thanked: 8 times
Sat May 14, 2016 8:02 pm
Just connected 5 Hikvision cameras (100M interface) and cable test is failing on all of them. It either says Short or Abnormal Termination on Pairs 3 and 4. Other than that everything seems to be working fine...
WS-1--250-AC
1.3.9
Board rev. E
Re: Pair 3, 4 Short or Abnormal Termination
Sat May 14, 2016 8:17 pm
That's normal behavior for a 10/100 device
Maybe do some searching and reading on this forum
Start with this thread: viewtopic.php?f=6&t=1178
cross-short is the bad ones to look for
But technically there is no Ethernet Standard that shorts pairs so of course it says fail
lacibaci
Sat May 14, 2016 10:50 pm
sirhc wrote:That's normal behavior for a 10/100 device
Start with this thread: http://forum.netonix.com/viewtopic.php?f=6&t=1178
OK, thanks. Maybe the cable tester message should be updated.
