Security
wpengland
Security
Fri May 13, 2016 1:40 pm
Is there a way to block MAC addresses with the WISP Switch?
Re: Security
Fri May 13, 2016 2:17 pm
No, sorry.
We could do it but why?
wpengland
Re: Security
Tue May 24, 2016 2:24 pm
So that a rogue user can be blocked before they hit one of our routers. Very common on most managed switches. This is a feature that will make or break me buying more of the Netonix product.
Re: Security
Tue May 24, 2016 2:40 pm
There are better ways to do this then a MAC access list as MAC list access control is only good on flat network segments and becomes useless beyond a single sub-net range.
Go to the Device/Access Control and you can specify allowed IP ranges.
There is also a Tar Pit on our switches which means people can not Brute Force Crack them.
wpengland
Re: Security
Sun May 29, 2016 11:20 am
Isn't that a list that allows access to the console of the switch? I really need to be able to control traffic on a MAC Level.
Re: Security
Sun May 29, 2016 11:26 am
The switch core is capable of this but it is not on our immediate road map of features.
This is not to say we may not consider implementing it at a later time.
