Camera Install
dhuestis
Has thanked: 3 times
Camera Install
Sat Apr 23, 2016 2:34 pm
I am working on a security camera project and was looking to use Netonix switches to power the cameras and Nanostations. The cameras have a barrel connector and require 12VDC with a max of 40W. Each building will have two cameras, one Nanostation, and has 110VAC available.
Questions:
1. What switch would work well for this?
2. Would anyone know of a POE splitter that would be compatible with the POE standard that Netonix switches use and that would handle enough wattage to power each camera?
Thanks!
Re: Camera Install
Sat Apr 23, 2016 3:30 pm
Probably would pay dearly for off-the-shelf so you would be best off to home-brew your own. Use 48V PoE at the switch, then a plain Jane passive PoE picker and convert the 48V to 12V at the camera end.
