RX Jabber Errors
zrob_12
RX Jabber Errors
Sat Mar 26, 2016 1:01 pm
Receiving many of these on one of my interfaces connected to a Master AF5X. What do these mean? We have tried different ports on switch and powering with a POE and no change? Thoughts?
Netonix is a WS-24-400A
We have replaced the AF5x and cable and no change.
On Slave side, Netonix is incurring a large number of RX Filtered Errors.
Running 1.3.9 on both switches
Re: RX Jabber Errors
Sat Mar 26, 2016 1:54 pm
There is a search box in the upper right corner of the forums to find answers to questions that have been asked before.
Searching for issues first prevents duplicate questions and keeps the clutter lower so people can find answers easier.
A quick search of the forums with "Rx Filter" yielded these posts
viewtopic.php?f=6&t=1163&p=8698&hilit=RX+Filter#p8698
viewtopic.php?f=6&t=817&p=6115&hilit=RX+Filter#p6115
viewtopic.php?f=6&t=817&p=6115&hilit=RX+Filter#p6116
viewtopic.php?f=6&t=747&p=5516&hilit=RX+Filter#p5516
Also Google Rx Filter which you will find little information on this as manufacturers use it as sort of a garbage error counter.
Then Google Rx Jabber and you will find a little more information that you may find helpful
http://www.thenetworkencyclopedia.com/entry/jabber/
http://www.webopedia.com/TERM/J/jabber.html
zrob_12
Thu Apr 07, 2016 8:25 pm
Thanks Chris - we were able to nail down the issue.
