So again I am a newb and I accidentally disabled HTTPS in the switch. I have a WS-10-250-AC. What is the command to re enable it in putty? Thank for your help.
Danny
GUI Access
legacyisp - Member
Re: GUI Access
You know I do not use the CLI very much so I do not know it but I can follow the bouncing ball pretty well.
I logged into the CLI or used a console cable
Then I pressed the "?" and got a list of commands.
Typed in "config" and pressed Enter to enter config mode
Then I typed "?" again to see the commands available in config mode
I noticed this one "https-server Set HTTPS server configuration"
Typed "https-server ?" for list of commands related to that
Typed in "https-server port 443" and pressed enter
Then did a [Ctrl] + [z] to leave config mode which will save/apply changes
legacyisp - Member
Users browsing this forum: No registered users and 26 guests
