Oxidized config backup
gr0mit
Been thanked: 7 times
Sat Mar 19, 2016 5:28 pm
Hi Folks
Is anyone using Oxidized to back up their configs? I'm using it for my Mikrotik and Cisco configs but I'm not sure where to start with the Netonix switches. Has anyone done it? If so, is there a Netonix config for Oxidized?
Thanks in advance
Best regards
Tim Robinson
Re: Oxidized config backup
Sat Mar 19, 2016 5:32 pm
There is an auto TFTP backup that saves the config to a TFTP server anytime a change is applied.
You configure it on the Device/Configuration Tab
gr0mit
Sat Mar 19, 2016 5:35 pm
Hi
Thanks for the quick reply! Oxidized seems to export the cisco and routeros configs by ssh'ing into it and exporting. It exports into a git repository so you have a history of changes...
https://github.com/ytti/oxidized
is the code. Is there a Netonix plugin for oxidized?
gr0mit
Sat Mar 19, 2016 5:43 pm
OK - here's the scripts for the different routers:
https://github.com/ytti/oxidized/tree/m ... ized/model
It doesn't seem too hard, but I'm not a developer so anything I write would have a large warning label attached! Any experts here who want to have a crack at this?!
taytrho
Has thanked: 4 times
Been thanked: 3 times
Mon Mar 21, 2016 2:50 pm
taking a brief look at the code, it doesn't seem too difficult. The command to view the configuration in the Netonix is "show config" but I'm unsure if oxidize needs more logic to essentially hit the space bar to keep showing the entire config. I'll keep poking around a little.
gr0mit
Tue Mar 22, 2016 6:54 am
Hi thanks for looking at this!
The other issue I've spotted is that my Oxidized system has a sperate user/pass just for backups. Is there a way to add in more users to the switch with different user/pass combinations?
Tue Mar 22, 2016 10:16 am
gr0mit wrote:Hi thanks for looking at this!
Only via Radius Authentification
gr0mit
Tue Mar 22, 2016 1:14 pm
Hi Sirhc
I've tried Radius - it auths fine with web access but not with ssh access. Have I missed something?
Also, is there a command to show running config without the page breaks?
Eric Stern
Been thanked: 130 times
Wed Mar 23, 2016 3:51 pm
gr0mit wrote:Hi Sirhc
Thats a bug. It will be fixed in 1.4.0.
gr0mit wrote:Also, is there a command to show running config without the page breaks?
Not from within the CLI, but you can drop to the command line
cmdline
cat config.json
exit
The "exit" gets you back to the CLI.
gr0mit
Thu Mar 24, 2016 12:35 pm
Update: I've been talking to the Oxidized developers - they've added Netonix support in already. I gave him SSH access to a switch and he;s done it already!
It looks like the code was only a few lines. So all good.
Kudos to Saku Yeti who responded so quickly.
Cheers
Tim
