WS-12-400-AC switch and Cisco MGBLH1 SFP Transceiver
YK-STelecom
Fri Mar 18, 2016 7:10 pm
Has anyone used the Cisco MGBLH1 Gigabit LH Mini-GBIC SFP transceivers to link two WS-12-400-AC switch and worked?
Fiber Specs: 6/F 8.3/125 single mode fiber
Thank you,
Re: WS-12-400-AC switch and Cisco MGBLH1 SFP Transceiver
Sat Mar 19, 2016 12:52 pm
Hi Young,
It was nice talking to you on the phone the other day. I spoke with our Engineer and we have asked our software engineer to order (2) of these modules to test with out switches.
I am 99.9% sure they will work as I said as they are Cisco compatible.
If by chance they do not work with the current firmware Eric will see what he can do.
As I said working with Marcus from Verizon a software feature he requested is in the v1.4.0rcX firmware so when you get your test units I would recommend installing v1.4.0rcX first before you start playing.
Also as I indicated Marcus had suggested that you guys might need "more" 48VH ports for your application with micro-cells so the next production batch of WS-12-400-AC units will have a version that offers (6) 48VH ports.
Marcus and I think a normal 48V port @.75A will probably be enough to power a micro-cell as 48V @.75A is rated for a 55C environment and if the switch is in a cool location can deliver 1A, keep in mind that the .75A rating is based on a Polyfuse which is sized to trip at .75A in 55C so if the switch is located in an environmentally controlled space it will not trip at .75A, probably more like 1A.
However driving 1A on a single pair is pushing the limits of the Ethernet transformers and I do not know what the rating of the transformers are in the micro-cell but ours are rated at 1A per pair.
But as I said a 48VH port uses all 4 pair to deliver 1.5A @ 55C so probably more like 2A at room temp.
And as I stated newer later versions of the WS-12-400-AC in the works will offer (6) 48VH ports.
You have my cell if you have any questions.
Thanks,
Chris
YK-STelecom
Mon Mar 21, 2016 11:06 am
Sounds great! Thank you for your help!
Eric Stern
Been thanked: 130 times
Wed Mar 23, 2016 5:11 pm
Tested these modules today, they work fine.
YK-STelecom
Wed Mar 23, 2016 7:08 pm
Thank you so much for the confirmation!
swang2002
Mon Apr 11, 2016 10:02 am
sirhc wrote:Also as I indicated Marcus had suggested that you guys might need "more" 48VH ports for your application with micro-cells so the next production batch of WS-12-400-AC units will have a version that offers (6) 48VH ports.
Any idea on when these might be available? I have a few places I could use them as well.
Mon Apr 11, 2016 10:09 am
6-8 weeks
Users browsing this forum: No registered users and 12 guests
