enabling QinQ
rebelwireless
Has thanked: 31 times
Been thanked: 136 times
enabling QinQ
Sat Feb 13, 2016 12:21 pm
how to enable/config QinQ? I'm not sure if I'm having a problem with mis-configuring the switch, or the VM environment... you guys are a little lite on documentation..
Re: enabling QinQ
Sat Feb 13, 2016 12:29 pm
Do a search of QinQ and you find posts like this: viewtopic.php?f=17&t=1033&p=7749&hilit=QinQ#p7749
One of the most common mistakes when using QinQ is not setting your MTU large enough.
rebelwireless
Re: enabling QinQ
Mon Mar 07, 2016 12:17 pm
Chris, can you just clarify, I need to make a change online and don't want to have an issue
I have a router that is in a 'router on a stick' setup in port1 of the netonix.
Port 1 is Router (RB850Gx2)
Port 7 is Backhaul (AF5X)
VLAN27
Port 1 VLAN 1 'U'
Port 1 VLAN27 'T'
Port 7 VLAN27 'U'
What do I need to change here? I though that changing Port1 VLAN27 to 'Q' would be it, but I'm not allowed to do that on 1.3.9 firmware... I can only change Port1Vlan1 from U -> Q, or Port7VLAN27 from U -> Q
Re: enabling QinQ
Mon Mar 07, 2016 12:34 pm
As you know you can only have 1 "U" per port.
In the current form you can only have 1 "U" or "Q" per port.
I am not sure we could allow a "Q" and "U" to assigned on the same port?
I have pinged Eric to weigh in here.
rebelwireless
Re: enabling QinQ
Mon Mar 07, 2016 12:44 pm
I don't need that. I just need to pass QinQ across VLAN27, which is configured as 'U' on port 7. That seems to be the issue.
If I run a separate VLAN on a link, with both 'T' then I can run QinQ across that just fine. I have a couple places that I can't do that right now though. Mid-transition here so I was looking to QinQ on 1 'T' and 1 'U' port to solve it. I thought that 'Q' was roughly the same a 'U' but didn't strip the QinQ vlans.
Re: enabling QinQ
Mon Mar 07, 2016 1:09 pm
Q will strip the outer VLAN Tag OFF
Meaning if a port has a Q on it and a packet is exiting that Q port and the Packet has VLAN Tag 1 inside VLAN Tag 2 the the packet will exit with only VLAN Tag 1 as ID was stripped.
If it is a packet with just VLAN ID 2 and no inner VLAN Tag then the packet will leave the port as an Untaged packet as the only single VLAN Tag was removed exposing an Untaged packet.
A packet entering a Q port will have an outer VLAN Tag installed encapsulating an already VLAN packet inside another VLAN ID
T will pass normal VLAN and QinQ VLANs without stripping the outer VLAN Tag off provided your MTU is large enough for double Tagged QinQ packets.
rebelwireless wrote:VLAN27
Port 1 VLAN 1 'U'
Port 1 VLAN27 'T'
Port 7 VLAN27 'U'
sirhc wrote:As you know you can only have 1 "U" per port.
What you said you wanted to do was change Port 1 VLAN27 from T to Q but you can not as Port 1 VLAN1 is a U and the UI will NOT allow this.
As I said you can NOT have a U and a Q on the same port, it is either one or the other.
Also as I said I am not sure if we can change this ability so I pinged Eric to respond if we can even allow a Q and U to exist on the same port.
Eric Stern
Been thanked: 130 times
Re: enabling QinQ
Mon Mar 07, 2016 3:23 pm
sirhc wrote:Also as I said I am not sure if we can change this ability so I pinged Eric to respond if we can even allow a Q and U to exist on the same port.
We cannot.
