help on ws to cisco switch....
- Has thanked: 31 times
- Been thanked: 136 times
Chris, in a bind, can't get a WS to talk to a cisco 3560x switch... what does port isolation mean to you guys, communicates when that is flipped...
Re: help on ws to cisco switch....
Read these posts found with a search for "Port Isolation":
viewtopic.php?f=6&t=1126&p=8391&hilit=port+isolation#p8391
viewtopic.php?f=6&t=426&p=5096&hilit=port+isolation#p5096
Port Isolation (but discussed a couple times on forum)
Any port with Port Isolation Enabled will not talk to any other port with Port Isolation also Enabled. Pretty much the same as client Isolation on an AP.
For port isolation:
viewtopic.php?f=6&t=426&p=5096&hilit=port+isolation#p2746
Seem Chris was faster than me.
I still don't know what the problem was. I had a port sending untagged vlan1 traffic,not in trunk or anything, and the cisco was throwing 'trunk port error'. The cisco was passing untagged by stripping a vlan out. the cisco would then block the port. port isolation was the fix...but it doesn't make sense because it shouldn't have been passing any other vlans..
