Hi all,
I searched the forums and saw a screenshot or two of someone powering what appears to be a AF5X via 24V. Is this the recommended setting for this device? The AF5X PoE Injector does indicate that it provides power on all 8 conductors, so I thought perhaps 24VH would be the right setting. Thanks for any feedback.
WISP Switch PoE Setting for Ubiquiti AF5X
Re: WISP Switch PoE Setting for Ubiquiti AF5X
I moved your post from the "Share Your Installation Pictures" thread to the WISP Switch General discussion thread.
Please read this post which was at the TOP as an announcement of the WISP Switch General discussion thread: viewtopic.php?f=6&t=1215
Thanks Chris -- 24VH or 24V if cable run is under 200' -- gotcha.
Thanks!
Thanks!
qlex wrote:Thanks Chris -- 24VH or 24V if cable run is under 200' -- gotcha.
Thanks!
Well if your unit supports 24VH and you have a special port available you can use 24VH at any cable length but also "NEW" AFX units support 48V and 48VH as well or so they claim I have been afraid to try it.
