Ceragon IP20c w/ Netonix ?
faisal
Mon Feb 01, 2016 8:06 pm
Hello,
Anyone has tried or knows if they can power a Ceragon IP20c radio with a Netonix Switch ? (48v 1.5amp port) ?
Thanks in advance.
Regards
Re: Ceragon IP20c w/ Netonix ?
Mon Feb 01, 2016 9:10 pm
faisal wrote:Hello,
Thanks in advance.
Regards
To clarify he means 48VH 1.2A/1.5A (depending on model/Rev)
Magician
Has thanked: 7 times
Been thanked: 31 times
Wed Feb 03, 2016 10:24 pm
Time to camp as I may be deploying one aswell :)
Fri Feb 05, 2016 2:47 pm
Looking at Cambium 820c spec sheet, seem like it would work except for 7 Ghz radios in 2+0 operation. Ethernet pineout information is missing.
Power Input Specifications
• Standard Input: -48 VDC
• IDU DC Input range: -40 to -60 VDC
Power Consumption Specifications
• Maximum Power Consumption (2+0
Operation) 6 GHz: 65W; 7 GHz: 75W; 11
GHz: 65W; 13-15 GHz: 55W; 18-24 GHz:
48W; 26-38 GHz: 55W
PoE Injector Mechanical Specifications
• Dimensions – 134mm(H), 190mm(W),
62mm(D), 1 kg
PoE Injector Environmental Specifications
• 33°C to +55°C (-45°C to +60°C extended)
PoE Injector Power Input Specifications
• Standard Input: -48 or +24 VDC (Optional)
• DC Input range: ±(18/40.5 to 60) VDC
(+18VDC extended range is supported as
part of the nominal +24VDC support)
PoE Injector Interfaces
• GbE Data Port supporting
10/100/1000Base-T
• Power-Over-Ethernet (PoE) Port
• DC Power Port –40V to -60V (a PoE
supporting two redundant DC feeds
faisal
Fri Feb 05, 2016 5:17 pm
Yeah, the same issue with the Ceragon manuals, key info is missing..
Their POE injector is rated to accept +/- 18v to 60v DC. so that is not an issue .. simple enough.
However the Radio (ODU) Is listed as only accepting -48v DC.
My question, if I someone knows... what is the difference (if any) between -48v DC vs 48v DC ? (I do understand that there is a + and - polarity in DC... ).
Regards
Sat Feb 06, 2016 11:21 pm
allencook
Wed Apr 06, 2016 12:07 pm
Was anyone successful?
Mac_SPITwSPOTS
Mon Apr 18, 2016 7:05 pm
Posting into here in the hopes someone finds the appropriate information for this.
Operations Management is key.
gripper
Sat Apr 30, 2016 5:24 pm
Did anybody figure this out?? Faisal--what did you end up powering with?
nickwhite
Has thanked: 9 times
Wed May 04, 2016 4:26 pm
I'm curious on this as well?
We're currently looking at the PTP820c and IP20c in 11Ghz and 18Ghz. I was told by a Ceragon person that there are a few compatible POE switches, and they thought there were some Juniper ones that worked. I was told yesterday by a Cambium person that "No. It is proprietary POE" to which I laughed internally.
