Dragonwave
Re: Dragonwave
DO not know yet do you have the pin out?
- keefe007
Re: Dragonwave
They just got back to me and said they use power on all pairs.
JustJoe - Experienced Member
- Has thanked: 94 times
- Been thanked: 59 times
Re: Dragonwave
Might the user guide have the actual labeled pins? (Maybe online?)
For instance, some Canopy likes to reverse the voltages, so it's something that is need to know for each manufacturer.
- keefe007
Re: Dragonwave
Here's what DW said:
Pins 1, 2, 4, and 5 are positive voltage from PSE
Pins 3, 6, 7 and 8 are negative voltage from PSE
Re: Dragonwave
YEP - GOOD TO GO WITH 48VH ports!!!!!
This is in the PDF http://store.netonix.com/media/wysiwyg/ws-specsheet.pdf
Re: Dragonwave
adairw wrote:Do it!
LOL
adairw - Associate
- Has thanked: 98 times
- Been thanked: 132 times
Re: Dragonwave
I plugged in a $4k exalt radio, assuming it would work.. So c'mon! Let's see some dragonwave smoke!
