Mass Upgrades
mhoppes
Has thanked: 10 times
Been thanked: 125 times
Mass Upgrades
Thu Jan 07, 2016 11:25 am
As the number of Netonix switches in our network begins to grow pushing out firmware updates is becoming a chore. Are there:
1) Any plans to release some sort of software to push out mass firmware updates?
2) A CLI command which can download a firmware file and initiate the flash from the CLI? (I can script the batch myself then).
Re: Mass Upgrades
Thu Jan 07, 2016 11:37 am
We are working on a web based portal similar to say airCONTROL where you manage and update your firmware of your switches.
One planned feature would be scheduled upgrades and that it will alert you if an upgrade fails.
It will be a web UI interface you host on Linux or Windows.
mhoppes
Re: Mass Upgrades
Thu Jan 07, 2016 11:38 am
:icon_cool:
Eric Stern
Been thanked: 130 times
Re: Mass Upgrades
Thu Jan 07, 2016 3:06 pm
mhoppes wrote:2) A CLI command which can download a firmware file and initiate the flash from the CLI? (I can script the batch myself then).
There is the "firmware upgrade" CLI command. Requires a TFTP url to fetch the firmware from.
mhoppes
Re: Mass Upgrades
Thu Jan 07, 2016 3:19 pm
Bah. Tftp
Re: Mass Upgrades
Thu Jan 07, 2016 3:26 pm
mhoppes wrote:Bah. Tftp
Just to be clear, it is not like UBNT TFTP recovery on boot. It is more like in HP Procurve management where TFTP is used for bi-directional file transfers.
mhoppes
Re: Mass Upgrades
Thu Jan 07, 2016 3:31 pm
I know. I prefer ftp or scp
Re: Mass Upgrades
Fri Jan 08, 2016 10:18 am
tftp work fine if you have no NAT between but since we have access to the command line, maybe scp would work.
Personnaly, I would like better a standard like TR069 than a Vendor UI like airControl. We don't like to have multiple software to do the same thing with different devices so we have our own custom customers/tickets/billing/backup/ip address/up~down/map management system sometime based on opensource project like nagios. The other advantage is that we're not lock to a single vendor.
Eric, is the're a way to also script Netonix shell script like it can be done with vyatta via vbash ?
http://vyos.net/wiki/Command_scripting
Eric Stern
Re: Mass Upgrades
Fri Jan 08, 2016 2:42 pm
mhoppes wrote:I know. I prefer ftp or scp
You could use scp too.
scp wispswitch-1.5.12.bin admin@<switch ip>:/tmp
Then at the CLI use "cmdline" to get to the linux command prompt and run "firmware_upgrade /tmp/wispswitch-1.5.12.bin"
Eric Stern
Re: Mass Upgrades
Fri Jan 08, 2016 2:43 pm
mike99 wrote:Eric, is the're a way to also script Netonix shell script like it can be done with vyatta via vbash ?
Not currently. But its easy enough to use expect over ssh.
Users browsing this forum: No registered users and 24 guests
