I'm curious if there are any negative ramifications when upgrading from a smaller (8 or 12 port switch) to a larger switch (24 port) at a site to just load the config file over?
Looking at the config it APPEARS the values for ports 13-24 are there, just ignored on the smaller switches. Is this a correct assumption?
Upgrading From Smaller Switch to Larger
Re: Upgrading From Smaller Switch to Larger
Yes you are supposed to be able to import the config from one model to another but it is a good idea (should not matter) that they be the same firmware version.
mhoppes - Associate
- Has thanked: 10 times
- Been thanked: 125 times
OK. So as long as they are the same firmware version, importing from one model to another should work OK you are saying...?
mhoppes wrote:OK. So as long as they are the same firmware version, importing from one model to another should work OK you are saying...?
Yes, but "technically" the firmware version does not have to match but is recommended.
mhoppes - Associate
So then let's just say it has to match
rockhead - Experienced Member
- Has thanked: 53 times
- Been thanked: 35 times
Doesn't have to match, shouldn't have to match, but for maximum safety ( belt and suspenders ) have them matched
It should not have to match but I do not check this obviously from all versions to all versions and from time to time things change in the file.
SHOULD NOT MATTER, famous last words.
All I am saying is the way it is designed it "should not matter" but if you want to play it safe I told you the safest method.
Not sure what else to say here, I am sure you want me to say "it does not matter period" but then I am on the hook if something goes wrong and you find yourself driving 100 Mph to the tower.
No thank you! - LOL
No thank you! - LOL
