LAG Question
mhoppes
Has thanked: 10 times
Been thanked: 125 times
LAG Question
Tue Dec 29, 2015 2:44 pm
If I have a Ubiquiti EdgeRouter connected to a Netonix switch can I enable LACP in such a fashion that it will only use one interface, unless that interface stops passing traffic and then it will use the other one? I don't want both used at the same time.
Scenario is:
Router--->Traffic Shaper--->Switch
In the event the traffic shaper stops passing traffic I want traffic to bypass it and continue. If I can't figure out a way to do it on switching fabric, the next step is to just put a second router after the traffic shaper and run OSPF, but that seems like overkill.
Re: LAG Question
Tue Dec 29, 2015 2:48 pm
You want RSTP not LAG
mhoppes
Re: LAG Question
Tue Dec 29, 2015 2:58 pm
Yes... but can I RSTP to a bond0 port on the router. that's the question.
mhoppes
Re: LAG Question
Tue Dec 29, 2015 3:08 pm
Ok.. So confirmed the Edgerouters will do a port bonding with a setting of active-backup. What would be the correct way to configure the switch to handle this setup?
