Changing some IP settings on a wisp switch, it never came back. It is up and running, powering devices, just can't get to it.
I may have fat fingered the IPs or the gateway. Anyway to do a discovery to see what it is doing or where it is hiding on me?
WISP Switch Discovery?
Re: WISP Switch Discovery?
If you are running the latest v1.3.9rcX you can use UBNT Discovery
TheHox wrote:Just had 1.3.3 I believe.
Yea, you're kinda down to wireshark and look for it or default it.
TheHox - Experienced Member
- Has thanked: 11 times
- Been thanked: 18 times
Derp, subnet/vlan issue was what I fat fingered. I found it. So checking "UBNT Discovery" will make this device available to ubnt discovery tool?
TheHox wrote:Derp, subnet/vlan issue was what I fat fingered. I found it. So checking "UBNT Discovery" will make this device available to ubnt discovery tool?
If you are running v1.3.9rc8 or newer firmware, it was broke before v1.3.9rcX
