At some point could you guys add to the software that ping watchdog gets disabled if the port is manually turned off? I had an ap die over the weekend and after shutting the port power off and disabling the port I was still getting watchdog emails. Would be nice if those could be turned off when the port is disabled. I ended up disabling the watchdog, but someone could easily forget to turn that back on once the module is fixed.
Please and thank you!
Feature Request
1 post
