Thanks for the screws!
sww
Been thanked: 10 times
Thu Dec 10, 2015 5:16 pm
I don't if it's intentional or you got a rogue employee over there but all my rack mount kits come with twice as many screws as I need. I actually really appreciate this because 9 times out of 10 my equipment comes back from towers missing a few.
So thanks! :D
Re: Thanks for the screws!
Thu Dec 10, 2015 5:58 pm
Take note, they are 2 different size screws as we changed the pem nuts in the chassis (bone head mistake) we are forced to provide both screws sizes.
1 is metric and one is SAE
sww
Thu Dec 10, 2015 7:24 pm
hmm, I must be grabbing the right ones by mistake each time. Hadn't noticed lol.
Thu Dec 10, 2015 8:37 pm
sww wrote:hmm, I must be grabbing the right ones by mistake each time. Hadn't noticed lol.
Well the smaller ones sorta work in both cases but the larger ones will not fit in unless you force them and then they could break off
