WS-8-250-DC fuse size?
- silverstr8p
- Has thanked: 3 times
What should I use for the DC power supply fuse size/circuit breaker size?
Dave - Employee
- Been thanked: 158 times
Re: WS-8-250-DC fuse size?
silverstr8p
If you are running with 24 volts or higher, a 15 amp fuse is ok.
If you are running with 23 volts or less, a 20 amp fuse is ok.
These are just general suggestions.
Users browsing this forum: No registered users and 20 guests
