WS-12-250-DC dimensions
wtm
Has thanked: 41 times
Been thanked: 36 times
Wed Nov 25, 2015 11:11 am
Installing a new cabinet, and have a tight rack space in it. I need the exact dimensions as depth of the WS-12-250-DC unit, from the rack going to the back for clearance, and from the rack coming to the front of what is needed for clearance. Published specs show 181 mm (also need in inches), but the published specs are the same for the AC and DC units, and I know that the DC jack sticks out longer in the front than that?
Thanks,
Wayne
Been thanked: 158 times
Re: WS-12-250-DC dimensions
Wed Nov 25, 2015 12:12 pm
Wayne
DC jack sticks out about 30mm but other than that the chassis is the same as the AC unit as far as dimensions.
Wed Nov 25, 2015 1:16 pm
Don't forget to allow space for airflow cuz if you think you are tight for space at the back, that is where the fan is.
Edit: maybe not... looking at pics it is on the side.
wtm
Wed Nov 25, 2015 2:09 pm
Thanks, There is plenty of room on the sides and between the vertical separation of the units, just not depth, pretty tight there. Figure I can go 10.5 inches from rack to back, and 1.5 inches in front (maybe)
