I'm looking at the WS-6-MINI as a replacement to the RB750UP and ERPOE-5 that we currently use. It looks very promising with great options.
Before I get one in here to check it out, can someone let me know:
Can I get "per Ethernet port" counters via SNMP? (ifInOctets, ifOutOctets, etc.)
FYI: This is something that is currently unavailable in ERPOE-5, and only recently available via RB750UP.
WS-6-MINI and per port stats via SNMP
Re: WS-6-MINI and per port stats via SNMP
YES
dcox - Member
- Has thanked: 5 times
have my first netonix ws-6-mini deployed in the field.
Went to graph it's port usage via SNMP, and getting no stats back on a per port interface (described above).
Running 1.3.9 firmware
Can someone give me an update, known bug?
This is not a bug, you're doing something wrong.
Are you using our MIB files? viewtopic.php?f=17&t=251
Also here are instruction to setup SNMP viewtopic.php?f=17&t=1253
dcox - Member
I'm looking at it now via snmpwalk, and there are indeed per port statistics being recorded, that's good.
However, my software isn't working right, it's Intermapper, and while it's early in the discovery process, one thing I noticed is that Netonix doesn't have a reported "type" like other hardware that I'm graphing.
For example, I don't see this when walking out the snmp:
IF-MIB::ifType.1 = INTEGER: ethernetCsmacd(6)
IF-MIB::ifType.2 = INTEGER: ethernetCsmacd(6)
IF-MIB::ifType.3 = INTEGER: ethernetCsmacd(6)
IF-MIB::ifType.4 = INTEGER: ethernetCsmacd(6)
IF-MIB::ifType.5 = INTEGER: ethernetCsmacd(6)
IF-MIB::ifType.6 = INTEGER: ethernetCsmacd(6)
And perhaps that is the reason why my software isn't graphing correctly.
I think the custom mib is unnecessary for simple ethernet stats, but I will import it and see if that helps.
dcox - Member
I should also say, I think it's missing reported MTU as well:
example:
IF-MIB::ifMtu.1 = INTEGER: 16436
IF-MIB::ifMtu.2 = INTEGER: 1500
IF-MIB::ifMtu.3 = INTEGER: 1500
IF-MIB::ifMtu.4 = INTEGER: 2286
IF-MIB::ifMtu.5 = INTEGER: 1500
IF-MIB::ifMtu.6 = INTEGER: 1500
example:
Users browsing this forum: No registered users and 14 guests
