Edit config file ?
jjonsson
Has thanked: 37 times
Been thanked: 65 times
Edit config file ?
Sun Oct 18, 2015 8:44 am
Is it safe to edit config file downloaded from switch with Notepad to change IP-address, or have you also saved some kind of checksum in the file to prevent tampering ?
jjonsson
Re: Edit config file ?
Thu Oct 22, 2015 4:37 pm
I tried changing IP-address. I couldn't get switch to apply config file afterward. Am I doing something wrong or is it just not possible to manually edit config file ?
Eric Stern
Been thanked: 130 times
Thu Oct 22, 2015 5:02 pm
This is possible and safe, but you aren't really supposed to do it that way. We have the GUI and the CLI for doing these things.
How are you trying to apply the changes? Worst case, a reboot should do it.
