How to mount WS-6-POE inside enc-sw-8x5 enclosure
abjornson
Has thanked: 5 times
Sat Oct 17, 2015 5:35 am
I love that you guys sell this handy enc-sw-8x5 enclosure on your site....really makes for a low cost / waterproof and easy to use outdoor installation.
I'm struggling a bit with how to mount the WS-6-POE inside the mini enclosure so that it doesn't fall out when I close up the enclosure.
I tried using the long wallmount screws that come with the WS-6-POE to just barely penetrate into the plastic of the enclosure....but they don't seem to dig in very well and I was leery of penetrating the outside of the box.
Right now, plugging in all the ethernet cables and getting the switch crammed back inside the enclosure once the thing is mounted on the wall is a bit painful....any suggestions?
Thanks in advance
Re: How to mount WS-6-POE inside enc-sw-8x5 enclosure
Sat Oct 17, 2015 8:53 am
There is no problem for the screws to go through the box and poke out the back. Just file off the pointy end after it is through. The screws will seal to the plastic.
The MINI does thermal transfer through the back so getting good contact helps to transfer the heat to the outside through the plastic.
Sat Oct 17, 2015 12:07 pm
I go to the hardware store and buy 8/32 thread stainless or zink plated screws just long enough to stick out the back then I buy a drill bit and 8/32 TAP.
Make sure the drill bit is a smaller diameter than the 8/32 screws / TAP then drill and tap the holes in the plastic box so it allows easy exchange of switch.
BE CAREFUL NOT TO STRIP WHEN TAPPING THREADS
You could also through hole and nut it with silicon but I like the threaded option best.
abjornson
Wed Oct 21, 2015 9:58 am
Thanks for the tip - Writing this from a rooftop in Nairobi, Kenya where I'll implement these tips right away :)
