Changing VLAN settings turned port off
- keefe007
I'm running 1.3.3 and I just experienced a weird bug. After disabling trunking on two ports the switch turn off power on one of them. The Ports page showed POE as enabled but the main page showed the port as off.
Dave - Employee
- Been thanked: 159 times
Re: Changing VLAN settings turned port off
will get eric/chris to comment, but it will have to wait until tomorrow probably as they are both traveling back home from WISPAPALOOZA 2015 today
Dave - Employee
can you look at your log & see if any warnings printed?
Yes please post up more information on how to re-produce this Keefe007 and we will see if we can get this fix in v1.3.5
