I purchased a few replacement fans and they come without the connectors attached. I ordered a few different connectors from Digikey thinking they were the right size but apparently I have no clue what I'm looking for.
Any direction on the connectors I need to purchase to get these fans to work?
Connectors for replacement switch fans?
- Airfibber
Re: Connectors for replacement switch fans?
We sell replacement fans and they come with ends properly wired. If you wire them up wrong you can fry your board or at minimum the fan circuit.
Just any fan won't always work as we use pulses to control fan speeds.
If your replacing a fan with a third party fan you can always use the end from the old fan.
Red is +
Black is -
Yellow is the sensor in the fan for RPM
Red is +
Black is -
