What are everyone's thoughts on the new OOBE rules? How do you think this is going to affect you and how do you plan to work around these new limitations?
I'm worred about new 'full band' gear costing quite a bit more. In ubnt land, basically extra airPRISM filters for transmitting. It will be a rather big hit in EIRP at the edges.
I'm not necessarily planning like this, but I'm thinking one model may very well be to have long range PTMP centered in unii3 , and then shorter range PTMP on the edges. backhauls in the upper unii1 win AF and sync.
These new rules are likely to make certain sites nearly permanent legacy mode as the loss in EIRP for some APs takes them way below thresholds.
Thoughts on upcoming OOBE limitations?
- Has thanked: 31 times
- Been thanked: 136 times
- Been thanked: 1362 times
Re: Thoughts on upcoming OOBE limitations?
I am still happy with the airMAX M5 line and part of me is afraid of switching as you mention.
sirhc wrote:I am still happy with the airMAX M5 line and part of me is afraid of switching as you mention.
but even that line has the new rules apply for newly shipped gear.
sirhc wrote:I am still happy with the airMAX M5 line...
What are you using for Rockets? I lost track of what issues there are WRT XM/XW and Ti. ISTR there were issues between XM clients and XW AP and that the Ti had port speed negotiation issues.
So, with the new EIRP rules and the grandfather clause, will it be based on firmware version meaning new firmware, new rules? So if you need the new FW to solve the issues you lose the GF clause?
lligetfa wrote:ISTR there were issues between XM clients and XW AP and that the Ti had port speed negotiation issues.
The issues between XM and XW firmwares have essentially all been fixed in 5.6.x firmwares.
UBNT soft-confirmed that the firmware will check the serial number of the device to determine new vs old rules so you can use new firmware on old devices without loosing the grandfather.
