Searching in forum
Ludvik
Has thanked: 15 times
Been thanked: 15 times
Searching in forum
Thu Feb 20, 2020 4:57 am
Hi.
Does the search work in this forum properly? I try search for example "WS12-250-DC" and result is nothing. This string is in: https://forum.netonix.com/viewtopic.php?f=17&t=6023
But "temperature" works.
Re: Searching in forum
Thu Feb 20, 2020 8:52 am
Maybe the hyphen that broke the search. If you search for dead, it work fine.
Ludvik
Thu Mar 05, 2020 5:36 pm
I don't know why I should look for the dead ... I am living animal.
I search information about the switch and I found nothing. It is big mistake. If your product's names are with hyphen, searching should work.
Thu Mar 05, 2020 6:10 pm
It is a quirk of the phpbb forum software. Closest I can suggest is to take out the hyphens and use spaces instead.
For example, if you search for "WS12 250 DC" it is not perfect but will include what you are looking for.
Been thanked: 158 times
Thu Mar 05, 2020 11:23 pm
Stephen is going to patch in a fix for this search issue...it is on his list to do for next week.
Been thanked: 207 times
Mon Mar 09, 2020 4:26 pm
Ludvick, there was a bug in the forum software, it has been patched, try your search now.
Mon Mar 09, 2020 4:53 pm
Eh Stephen, I was about to hit you up with a Kudo but the option is gone.
Mon Mar 09, 2020 5:02 pm
yeah just saw that. Working on it.
Ludvik
Mon Mar 09, 2020 8:38 pm
thanks
Tue Mar 10, 2020 4:56 am
OK, the patch didn't want to cooperate with some of our mods and customization's but it's working now.
Return to The Lounge
