What does this mean?
Dec 11 13:17:33 monitor: restarting vtss_appl
And why did it happen?
restarting vtss appl
- Michael Day
Eric Stern - Employee
- Been thanked: 130 times
Re: restarting vtss appl
That is the process that handles many functions of the switch. It crashed and was automatically restarted by the monitoring service. There isn't really a way to tell why. If it happens frequently it may indicate a hardware issue with the switch.
- Michael Day
Thank you. I do have pre-programmed spares if needed.
- skapur
We have experienced similar issue with one of our Netonix switches where adding 4 VLANs resulted in a restart of this module and dropped a physical interface as seen in the below logs:
The switch is running on firmware version 1.4.9
Do you think this is because of hardware fault on this switch?
- Code: Select all
Sep 17 11:31:48 UI: VLANs: added 'VLAN17'
Sep 17 11:31:48 UI: VLANs: added 'VLAN18'
Sep 17 11:31:48 UI: VLANs: added 'VLAN19'
Sep 17 11:31:48 UI: VLANs: added 'VLAN20'
[b]Sep 17 11:31:57 monitor: restarting vtss_appl[/b]
Sep 17 11:31:59 LACP: starting negotiation with partner E4-8D-8C-35-72-82
Sep 17 11:31:59 Port: link state changed to 'up' (1G) on port 13
Sep 17 11:32:00 Port: link state changed to 'up' (1G) on port 13
Sep 17 11:32:00 Port: link state changed to 'down' on port 14
Sep 17 11:32:00 LACP: starting negotiation with partner E4-8D-8C-35-72-82
Sep 17 11:32:00 Port: link state changed to 'up' (1G) on port 14
Sep 17 11:32:02 LACP: LACP changed state to Active on port 13 (key 1)
Sep 17 11:32:04 LACP: LACP changed state to Active on port 14 (key 1)
Sep 17 11:32:04 STP: set port 15 to discarding
Sep 17 11:32:04 STP: set port 13 to discarding
Sep 17 11:32:04 STP: set port 14 to discarding
Sep 17 11:32:06 STP: set port 15 to learning
Sep 17 11:32:06 STP: set port 13 to learning
Sep 17 11:32:06 STP: set port 14 to learning
Sep 17 11:32:06 STP: set port 15 to forwarding
Sep 17 11:32:06 STP: set port 13 to forwarding
Sep 17 11:32:06 STP: set port 14 to forwarding
Sep 17 11:32:13 UI: Error occured during TFTP auto backup: tftp: timeout
- Been thanked: 1362 times
NO.
Upgrade your firmware and see if the problem is still there.
We are on v1.5.1rc4
v1.4.9 is 10 months old.
- airlinkrb
We are seeing this problem as well. We are on 1.5.0 ... going to upgrade to the latest RC and see what happens.
- airlinkrb
No Luck, sirhC.
Still seeing this in the logs.
Jan 1 00:00:12 netonix: 1.5.1rc5 on WS-12-250-DC
Jan 1 00:00:15 system: Setting MAC address from flash configuration: EC:13:B2:82:CA:C6
Jan 1 00:00:19 admin: adding lan (eth0) to firewall zone lan
Dec 31 18:00:35 admin: removing lan (eth0.99) from firewall zone lan
Dec 31 18:00:39 admin: adding lan (eth0.99) to firewall zone lan
Dec 31 18:00:45 admin: adding lan (eth0.99) to firewall zone lan
Dec 31 18:00:48 system: starting ntpclient
Dec 31 18:00:53 switch[1413]: Detected warm boot
Dec 31 18:00:55 system: starting ntpclient
Sep 18 16:59:54 system: time set by NTP server
Sep 18 17:00:15 monitor: restarting vtss_appl
Sep 18 17:01:22 monitor: restarting vtss_appl
Sep 18 17:01:35 monitor: restarting vtss_appl
- airlinkrb
When the vtss_app1 line shows up in the log, we see a couple of packets lost when pinging customers beyond the switch. We also see a dip in traffic throughput all happen for a bit at the same time.
- Casey
- Casey
Then there are 2 things possibly occurring:
1) The config is corrupted, a power on factory default then manually set the switch up.
How do do a power on default is explained here: viewtopic.php?f=6&t=409#p2398
2) As Eric said above your switch is damaged and need repaired.
RMA instructions are located here: viewtopic.php?f=6&t=1259#p9343
You could also bench test it as explained in detail here: viewtopic.php?f=6&t=2780#p19221
- nroufus
I recently just started experiencing this error. Every time it occurs, we see a latency spike/packet loss across the switch itself and all connected devices, throughput dropping, as well as port errors incrementing. We've tried two different switches and experiencing the same on both. WS-12-250-AC (original, first occurred here) and WS-12-250-DC (new replacement), both running 1.5.0. Did try a hard reset and configuring by hand (as suggested above). Same symptoms. Any ideas?
(EDIT) I was finally able to get it to stop by disabling the Discovery Tab. Updating to 1.5.1rc7 alone did not fix my issue. After re-enabling it, the logs display the "restarting vtss appl" error every minute, almost on the dot. Disabled again, and haven't had an issue since.
