One of the tower sites I own I have a broadcaster that wants to install a FM transmitter at 30kw (erp 75-80kw) on a 100' tower. Most of our gear is between 25-40feet with 3 radios at the top. They've offered more $$$ for their lease then WISP income for the site, so....
They want to install their bays between 60-90'. Currently we have home cable runs to the top, but I know that's not going to work once they get on-air. I have 100' roll of 1/2" copper tubing and I'm thinking I could run two runs of shielded double jacket cat5e up to the top through the copper tubing and stick a WS-6-mini up there and be good. Thoughts?
I have a few sites where we're co-located with other FM stations but those sites are all less than 500w with ERP less than 2kw and our normal cable as is has been fine.
Ethernet and FM broadcast site
LRL - Experienced Member
- Has thanked: 19 times
- Been thanked: 49 times
-LRL
- Been thanked: 1362 times
Re: Ethernet and FM broadcast site
My crystal ball is broken but sounds like it should work?
We're all installed and I hope for the best!
Even decided to use the copper tubing for our ground run and stuck the mini in a metal box with the copper bonded to it. The station is suppose to be on the air by the end of November, guess we're see once they crank it up.
-LRL
