CLI Commands
- SYS7EM-Kris
CLI Commands
Anyone know where I can get a list of CLI Commands for Netonix switches running 1.4.6 firmware? I am trying to figure out how to do a rapid ping
- Been thanked: 1362 times
Re: CLI Commands
SIMPLY hit "?" and press enter it provides a list of commands available where you are just like a Cisco router
If you type a partial command followed by a "?" and press enter it shows how to complete the command
If you can not follow the bouncing ball in the CLI to get help I am not sure how a printed list would help.
This way the help is always 2 keystrokes away.
- SYS7EM-Kris
Re: CLI Commands
Got it. Thanks. I was going to try the question mark like Cisco and Juniper I just have not been in the CLI of a Netonix and my guys are in the field getting one installed on our back bone so I wanted to see if I could find out how to do it before hand.
Re: CLI Commands
First go at the CLI and tbh the help wasn't a lot of use. Once you're done in configure mode, how do you write the config? Not in the help. So what do I do? I "end" to get out of config mode - and this triggers the save.
Netonix can you hire someone please to spend a few days on basic documentation?
