Have a 500' run total distance from house to CPE for a new client. CPE will be on 40' antenna tower out in a pasture.
What are you guys using to cable & provide power in a situation like this?
500' House to CPE / Best cabling?
Re: 500' House to CPE / Best cabling?
I use a WS-6-MINI midspan powered by PoE.
rkelly1 - Experienced Member
- Has thanked: 12 times
- Been thanked: 27 times
Thanks. Midspan would be in the middle of a horse riding area so an electronics box there is a no go. Thinking fiber/separate power may be the only way.
Just got off the phone with the client. Turns out they will be installing a fence for the riding arena about midspan.
In that case that could be a good place for a MINI. Might want to consider a future use for cameras or outdoor WiFi there as well.
I have a few mini's in stock too. If the midspanMini is at about 300', do you think a UBNT 48v AF POE provide enough power from the house side?
- Been thanked: 1362 times
If your trying to save money you could try this:
Use GOOD CAT6 direct burial cable as I have gotten 500' 10/100 connection at 500'
I would first spool off 500' and test before I went and buried it.
Other Options:
Fiber and DC power and EdgePOINT 6
Other Options:
rkelly1 wrote:I have a few mini's in stock too. If the midspanMini is at about 300', do you think a UBNT 48v AF POE provide enough power from the house side?
Mine is powered by a WS-24 and the AF PoE is actually 50V which is the same as what the Netonix puts out. I only see excessive voltage drop when the heaters kick in on the cams. It is just cosmetic (log entries) but if it bothered me enough I would power it with the 54V Ubiquiti PoE to compensate for the drop. The 24V side is not affected.
Probably you would never draw that much current.
- Has thanked: 31 times
- Been thanked: 136 times
We do stuff like this often enough. you can get 100Mbps on 500' of CAT5e pretty easily. Usually run 2 lines and dedicate 1 to power. Then I get these inexpensive 24v power supplies that can be tweaked up to about 27v which can account for some cable loss without overpowering the radio.
With a dedicated CAT5e for power, you'll be over 20v on the radio, if you just run it on the blue/brown pairs you'll be closer to 16v *but* the radio will fluctuate in draw enough that the volts will jump around a bit. Anything over 400' I'd typically run a landscape lighting wire, 16/2 is fine for a single radio.
I've got a 800' run on a fence and I'm using 14/2 and have a midspan mikrotik switch (260GS) that is pulling power off that 14/2. Get a full gig on both legs.
