Origional Rocket Dish + RF Armor + Airfiber 5 x
RF Armor®™ is not associated with Netonix® in any way.
isaacu
Wed Apr 12, 2017 5:31 pm
RF Armor for Rocket + AirFiber 5X? Will it fit? No speculation, I need to know if anyone has actually tried it. I have some Rocket fired links to upgrade.
Re: Origional Rocket Dish + RF Armor + Airfiber 5 x
Wed Apr 12, 2017 6:09 pm
Older Dish Kits will not fit the AFX radios or airPRISIM radios.
Newer Dish Kits UDK25X, UDK3X, and UDK5X will fit any Rocket including AFX or airPRISIM
https://www.rfarmor.com/dish-kits/udk25.html
https://www.rfarmor.com/dish-kits/udk3.html
https://www.rfarmor.com/dish-kits/udk5x.html
If you have an older kit you only need to upgrade the Box which is easily done on a tower, below are upgrade boxes for older kits:
https://www.rfarmor.com/dish-kits/uds25.html
https://www.rfarmor.com/dish-kits/uds3.html
We also make boxes now for several of the airFIBER dishes:
https://www.rfarmor.com/dish-kits/uds5g23-s45.html
https://www.rfarmor.com/dish-kits/uds5g30-s45.html
I use them all at my WISP and yes they fit nicely and work great.
Return to RF Armor™
