UBNT keeps increasing the size of the Rocket type models and we will buy new shield kits of course. The RF Armor shops says "The airPRISIM Rockets do not fit properly but you can fit them into the box.". Does that include the upcoming Rocket AC Prism (unavailable in Europe yet) or was it meant to refer to the Rocket AC PTP and PTMP types which also feature airPRISM but are a little smaller than the Rocket AC Prism will be?
Also, what do you mean by saying "they do not fit properly ... but you can fit them"? Will they not snap in and be "dangling" in the box? Or something else that we would have to do to make them fit?
USK1205AC (and others) fitting Rocket AC Prism
Re: USK1205AC (and others) fitting Rocket AC Prism
We already re-designed the Dish Kits viewtopic.php?f=38&t=881&p=10663&hilit=UDK25X#p10663
The original UDK25 evolved into the UDK25-AC which a few months ago evolved into the UDK25X which fits all including AF2X and AF5X radios
The original UDK3 evolved into the UDK3-AC which a few months ago evolved into the UDK3X which fits all including AF3X radios
The original UDK5 evolved into the UDK5-AC which a few months ago evolved into the UDK5X which fits all including AF5X radios
The UDS25 evolved into the UDS25AC which a few months ago evolved into the UDS25X which fits all including the AF2X and AF5X
*** This will convert an older dish kit into the X Dish Kit
The UDS3 evolved into the UDS3AC which a few months ago evolved into the UDS3X which fits all including the AF3X
We are currently work on all the sector kits to upgrade them to work with the larger AC Prisim Rockets.
You can cram the AC airPRISIM Rockets into the sector kits made for the past few years but not the original kits made from 2009-2010 that had small covers. You know the shield kits that weight a ton and used welding.
We are also working on Radio Cover Boxes for all the newer AF Dishes and lot more.
Here is a video showing they (airPRISIM Gen 2) fit properly in the new X version of RF Armor shield kits
https://youtu.be/laaV2CpIc4Q
