Metallic paint
RF Armor®™ is not associated with Netonix® in any way.
jjonsson
Has thanked: 37 times
Been thanked: 65 times
Metallic paint
Sun Jan 24, 2016 3:53 pm
I have some PowerBeam AC-500 with RF Armor shielding. I know they bleed RF from the back and i want to paint them with metal (fluid thinfoil ?)
Any recommandation of what kind of paint to use ?
Re: Metallic paint
Sun Jan 24, 2016 4:02 pm
If you remember way back we used to include a metal disk shield with the NanoBridge kits.
We found that the leakage out the back was SMALL and not worth the pain and the ass these little disks provided.
If you take a unit with my kit without the stem dish shield and compare it to the metal plastic coated backs you will find this is more advertisement FLUFF! then actual benefit!!!
Return to RF Armor™
