Finding it difficult to get a straight answer on this.
Do the UDK5X and UDK25X dish kits fit the newer AF-5G34-S45 and AF-5G30-S45 antennas?
Some say that it fits, some say it doesn't and some say it's a pointless exercise.
We have quite noisy towers, so like to have all the RF shielding we can get. We've used RF Armor pretty much everywhere in the past and would like to keep using it on the newer antennas if there's any benefit to it.
UDK5X/UDK25X on AF series antennas
- scottb
Re: UDK5X/UDK25X on AF series antennas
scottb wrote:Do the UDK5X and UDK25X dish kits fit the newer AF-5G34-S45 and AF-5G30-S45 antennas?
I do not see how on the 30dB, no holes to bolt it to it.
Not sure about the 34 dB
scottb wrote:Some say that it fits
NO, they do not....well as said not the 30 dB
scottb wrote:some say it doesn't
Correct....well same as above
scottb wrote:and some say it's a pointless exercise.
NO, they are wrong if they are implying the shields do not help.
scottb wrote:We have quite noisy towers, so like to have all the RF shielding we can get. We've used RF Armor pretty much everywhere in the past and would like to keep using it on the newer antennas if there's any benefit to it.
Use original antennas with slant 45 adapters with shield kits then compare to new antennas without shield kits....there is a difference.
