Radius VSA Attributes
rnscherdon
Fri May 07, 2021 3:18 pm
Does anyone have any knowledge on if Netonix equipment are radius compatible? Are there any VSA attributes out there for FreeRadius for read/write and read only logins? Not finding anything with my search.
Been thanked: 207 times
Re: Radius VSA Attributes
Mon May 10, 2021 8:07 pm
Should be,
Take a look at 34:12 here:
https://www.youtube.com/watch?v=8JvBEAD4MFM
Configuration option is under Device->Configuration Tab
sakita
Has thanked: 110 times
Been thanked: 90 times
Mon May 10, 2021 9:14 pm
We use FreeRADIUS with Netonix switches and it works fine.
However, there are no user permissions to pass back to the switch (there is no such thing as a read-only login on these switches).
It will login immediately if the local user name / password is entered. This is different than some other products which always try the RADIUS server first and will only login with local credentials when RADIUS is not available.
Return to Dave's Lab
