WS-6-MINI + Ubiquiti EP-54V-72W
cris.abbott
Mon Apr 06, 2020 9:52 pm
So while looking at the info page for the WS-6-MINI, I noted that it specifies that you shouldn't power the unit with 2-pair passive 48V PoE. The EP-54V-72W provides 54V 2-pair passive PoE. I presume that I shouldn't use that output to power the unit, and that I should use the barrel jack instead?
And that aside, does the WS-6-MINI condition the output PoE power to 48V, or does it pass through the 54V? If I read the documentation correctly, I believe that it passes the voltage through, but is able to monitor the current draw.
-Cris
Re: WS-6-MINI + Ubiquiti EP-54V-72W
Mon Apr 06, 2020 10:02 pm
You can use 2 pair power only if you keep the wattage load low. The voltage in is the voltage out minus the .7V drop across each diode. There is no conditioning.
Return to Dave's Lab
