Netonix-R20 Netonix-R35
MSTP - Enable Name:R3 Revision:3 MSTP - Enable Name:R3 Revision:3
Priority:32768 Priority:28672
Bridge ID:32768-EC-13-B2-82-65-0E Bridge ID: ID:28672-EC-13-B2-83-1A-12
Root Bridge ID:28672-EC-13-B2-83-1A-12 Root Bridge ID:28672-EC-13-B2-83-1A-12
E1------------ Vlan1 ---PC ----
172.20.20.1/24 E1---------Vlan1--PC----
172.20.35.2/24
Vlan3410 ------
192.168.10.2/24 Vlan3410 ----
192.168.10.1/24
Vlan3411--------192.168.11.2/24 Vlan3411-----192.168.11.1/24
E2-------------------------------------------------------------------------------------------------------E2
Vlan3410 - MST-Instance1-Root Vlan3410 - MST-Instance1-Designated
Vlan3411 - MST-Instance2-Alternate Vlan3411 - MST-Instance2-Designated
E3-------------------------------------------------------------------------------------------------------E3
Vlan3410 - MST-Instance1-Alternate Vlan3410 - MST-Instance1-Designated
Vlan3411 - MST-Instance2-Root Vlan3411 - MST-Instance2-Designated
- Under normal operating conditions, traffic from the Vlan3410 flows through E2 between both Netonix devices.
Example: Ping from 192.168.10.1 to 192.168.10.2
- Under conditions of connection failure in E2, traffic from the Vlan3410 flows through E3 between both Netonix devices.
- Under normal operating conditions, traffic from the Vlan3411 flows through E3 between both Netonix devices.
Example: Ping from 192.168.11.1 to 192.168.11.2
- Under conditions of connection failure in E3, traffic from Vlan3411 flows through E2 between both Netonix devices.
Fail A:
- Under normal conditions, traffic from 192.168.10.1 to 192.168.10.2 flows through E2.
- Action: Break the connection between E3, wait 1 second, then resume the connection between E3.
- Failure: Traffic between 192.168.10.1 and 192.168.10.2 stops flowing.
Failure B:
- Under normal conditions, traffic from 192.168.11.1 to 192.168.11.2 flows through E3.
- Action: Break the connection between E2, wait 1 second, then resume the connection between E2.
- Failure: Traffic between 192.168.11.1 and 192.168.11.2 stops flowing.
log results:
Netonix-R20
Dec 31 19:28:45 syslogd started: BusyBox v1.19.4
Dec 31 19:28:45 UI: Log cleared by admin (::ffff:172.20.20.250)
Dec 31 19:29:11 Port: link state changed to 'down' on port 3
Dec 31 19:29:11 STP: MSTI2: New root on port 2, root path cost is 0, root bridge id is 0.00-00-00-00-00-00
Dec 31 19:29:11 STP: msti 2 set port 3 to discarding
Dec 31 19:29:11 STP: msti 2 set port 2 to learning
Dec 31 19:29:11 STP: msti 2 set port 2 to forwarding
Dec 31 19:29:13 Port: link state changed to 'up' (100M-F) on port 3
Dec 31 19:29:13 STP: msti 0 set port 3 to discarding
Dec 31 19:29:13 STP: msti 1 set port 3 to discarding
Dec 31 19:29:13 STP: msti 2 set port 3 to discarding
Dec 31 19:29:13 STP: MSTI2: New root on port 3, root path cost is 0, root bridge id is 0.00-00-00-00-00-00
Dec 31 19:29:13 STP: msti 2 set port 2 to discarding
Dec 31 19:29:13 STP: msti 2 set port 3 to learning
Dec 31 19:29:13 STP: msti 2 set port 3 to forwarding
Dec 31 19:29:32 Port: link state changed to 'down' on port 2
Dec 31 19:29:32 STP: MSTI0: New root on port 3, root path cost is 0, root bridge id is 28672.EC-13-B2-83-1A-12
Dec 31 19:29:32 STP: msti 0 set port 2 to discarding
Dec 31 19:29:32 STP: MSTI1: New root on port 3, root path cost is 0, root bridge id is 0.00-00-00-00-00-00
Dec 31 19:29:32 STP: msti 1 set port 2 to discarding
Dec 31 19:29:32 STP: msti 0 set port 3 to learning
Dec 31 19:29:32 STP: msti 0 set port 3 to forwarding
Dec 31 19:29:32 STP: msti 1 set port 3 to learning
Dec 31 19:29:32 STP: msti 1 set port 3 to forwarding
Dec 31 19:29:35 Port: link state changed to 'up' (100M-F) on port 2
Dec 31 19:29:35 STP: msti 0 set port 2 to discarding
Dec 31 19:29:35 STP: msti 1 set port 2 to discarding
Dec 31 19:29:35 STP: msti 2 set port 2 to discarding
Dec 31 19:29:35 STP: MSTI0: New root on port 2, root path cost is 0, root bridge id is 28672.EC-13-B2-83-1A-12
Dec 31 19:29:35 STP: msti 0 set port 3 to discarding
Dec 31 19:29:35 STP: MSTI1: New root on port 2, root path cost is 0, root bridge id is 0.00-00-00-00-00-00
Dec 31 19:29:35 STP: msti 1 set port 3 to discarding
Dec 31 19:29:35 STP: msti 0 set port 2 to learning
Dec 31 19:29:35 STP: msti 0 set port 2 to forwarding
Dec 31 19:29:35 STP: msti 1 set port 2 to learning
Dec 31 19:29:35 STP: msti 1 set port 2 to forwarding
Copyright 2014-2019 Netonix
Netonix-R35
Dec 31 19:25:36 syslogd started: BusyBox v1.19.4
Dec 31 19:25:36 UI: Log cleared by admin (::ffff:172.20.35.250)
Dec 31 19:25:39 Port: link state changed to 'down' on port 3
Dec 31 19:25:39 STP: msti 0 set port 3 to discarding
Dec 31 19:25:39 STP: msti 1 set port 3 to discarding
Dec 31 19:25:39 STP: msti 2 set port 3 to discarding
Dec 31 19:25:43 Port: link state changed to 'up' (100M-F) on port 3
Dec 31 19:25:43 STP: msti 0 set port 3 to discarding
Dec 31 19:25:43 STP: msti 1 set port 3 to discarding
Dec 31 19:25:43 STP: msti 2 set port 3 to discarding
Dec 31 19:25:44 STP: msti 0 set port 3 to learning
Dec 31 19:25:44 STP: msti 0 set port 3 to forwarding
Dec 31 19:25:44 STP: msti 1 set port 3 to learning
Dec 31 19:25:44 STP: msti 1 set port 3 to forwarding
Dec 31 19:25:44 STP: msti 2 set port 3 to learning
Dec 31 19:25:44 STP: msti 2 set port 3 to forwarding
Dec 31 19:25:55 Port: link state changed to 'down' on port 2
Dec 31 19:25:55 STP: msti 0 set port 2 to discarding
Dec 31 19:25:55 STP: msti 1 set port 2 to discarding
Dec 31 19:25:55 STP: msti 2 set port 2 to discarding
Dec 31 19:25:59 Port: link state changed to 'up' (100M-F) on port 2
Dec 31 19:25:59 STP: msti 0 set port 2 to discarding
Dec 31 19:25:59 STP: msti 1 set port 2 to discarding
Dec 31 19:25:59 STP: msti 2 set port 2 to discarding
Dec 31 19:26:00 STP: msti 0 set port 2 to learning
Dec 31 19:26:00 STP: msti 0 set port 2 to forwarding
Dec 31 19:26:00 STP: msti 1 set port 2 to learning
Dec 31 19:26:00 STP: msti 1 set port 2 to forwarding
Dec 31 19:26:00 STP: msti 2 set port 2 to learning
Dec 31 19:26:00 STP: msti 2 set port 2 to forwarding
