Hi Guys,
couple of DC switches with fans burned.
Looking online for part MB40202VX-000U-G99 has come with no success.
Do you know where can we purchase those? any other replacement PN maybe?
Thanks!
Replacement fan
- info@rinkusoluciones.com
Re: Replacement fan
Re: Replacement fan
Just verifying --- getting under the hood to replace some burned up fans doesn't void the warranty does it? (I've got a WS-24-400B with a couple of bad fans as well).
Thanks!
Thanks!
Re: Replacement fan
csanger wrote:Just verifying --- getting under the hood to replace some burned up fans doesn't void the warranty does it? (I've got a WS-24-400B with a couple of bad fans as well).
Thanks!
There is no way a WS-24-400B is still in warranty.
