Ring
bradsdb
Ring
Mon Feb 13, 2017 6:39 pm
Have you guys looking into supporting Ethernet Ring Protection?
Wifimax
Re: Ring
Sun Feb 19, 2017 12:04 pm
+1 I would pay quite a bit for that.. I wonder what that would take to make a switch with support for ERPS?
Eric Stern
Been thanked: 130 times
Re: Ring
Mon Feb 20, 2017 11:19 am
We've added this to the list of features to add in the future.
Wifimax
Re: Ring
Mon Feb 20, 2017 3:13 pm
Wow thats incredible, are the current line of switches compatible with ERPS? Or will you need a new switch lineup?
Been thanked: 158 times
Re: Ring
Mon Feb 20, 2017 3:30 pm
same line...
Our software developer will contact you at some point to hopefully talk you into testing the rc release for us....
Been thanked: 1362 times
Re: Ring
Mon Feb 20, 2017 3:44 pm
It is supported by our existing switch core.
Eric hopes to release v1.4.7rc12 by Friday which will have this feature - ERPS
Wifimax
Re: Ring
Mon Feb 20, 2017 4:16 pm
This is huge for us... Thank you guys so much. :hurray:
Eric Stern
Re: Ring
Wed Feb 22, 2017 3:39 pm
So it turns out this won't be as easy to implement as we first though. It can still be done, but will be a lot more work than we originally thought.
Why do you need this feature? It seems like it is just like MSTP but less useful (ERPS only works in a ring configuration, MSTP works in any configuration).
Wifimax
Re: Ring
Thu Feb 23, 2017 3:24 pm
Here is the best G.8032 explanation, and future enhancements. It will support a ladder topology instead of just rings eventually.
http://www.actusnetworks.com/new/html/2.pdf
But for me personally:
1. Convergence times for fault detection at 50ms out of the box (this is huge for those of us for customers with SLA's)
2. Extremely extremely simple to setup and it scales well
3.All our fiber vendors support G.8032, Calix, Accedian, etc... In a world that is going more to a Hybrid Fiber/Wireless scenario this gives us quite a few possibilities to build parts of our ring with wireless instead of 100% fiber.
Siklu is also coming out with backhauls that support ERP: http://www.balticnetworks.com/siklu-eth ... ennas.html
jclendenan
Re: Ring
Sat Feb 25, 2017 4:40 pm
Cool!!! this would be a huge advantage to replace spanning tree protections :hurray:
Return to Dave's Lab
