What can I expect internal power consumption of the WS-Mini to be? I've noticed that my WS-8-250-DC uses about 8 Watts when the fan isn't running and without heavy network traffic. I'm using it for a solar repeater and am thinking that if I used the WS-6-Mini and a third-party DC regulator then maybe I could get less standby drain. It's no good to have your switch consume twice what your network gear uses.
Would using a WS-6-Mini do any good? Or can anyone recommend a better way to save power?
Power consumption of WS-6-Mini
- Been thanked: 1362 times
Re: Power consumption of WS-6-Mini
4 watts +/-
This is not a low power Switch Core (VSC-7424), it offers the same features as our larger models such as the WS-24-400A so there are trade offs and power consumption is one but you get a boat load for those 2 extra watts.
If we used a low end SOHO switch core like other vendors such as the BCM-53115 power consumption would be less than 2 watts but then people would complain about buffers being too small and throughput issues.
This is basically the same switch core as in out WS-24-400A with all the same abilities which is the VSC-742X series with the same amount of memory and flash as it's bigger brother.
The VSC-742X architecture is was designed as a solution for small to medium Enterprise or entry level Carrier switching - SME
The BCM53115 architecture is the optimal solution for consumer switching - SOHO
That makes sense. In other words, "you get what you pay for" both in terms of money but also in terms of power.
Unfortunately for me, my internet source doesn't get above 1Mbps even on a good day so enterprise level speed doesn't do me any good. Maybe you could put the self-consumption in the data sheet so so less informed buyers like me could see it before buying. I do have another project coming up that it will be perfect for so I'm not complaining, just suggesting for other's benefit.
Good luck with your business.
