WS 12 250 DC User Manual ...No can fund ???
This is my personal thread to share practices that have served my WISP well
sdwisp
Has thanked: 4 times
Been thanked: 3 times
Mon Aug 24, 2015 7:54 pm
So I now have my new DC switch and I'm looking for the User Manual. The provided paper work tells me to look for "The Basics and Examples" No Luck ? What is it that I;m missing ???
Help I install my new switch in 2 days
:headb: :headb: :headb: :screwb: :screwb: :screwb:
Eric Williams
619-468-9600
SDWISP
Re: WS 12 250 DC User Manual ...No can fund ???
Mon Aug 24, 2015 8:16 pm
Ask me anything that needs explaining in the UI or what simply pressing "?" in the CLI does not answer for you.
There are a lot of Balloon on mouse over to help identify some input fields.
We designed this interface to be EXTREMELY simple yet powerful.
Our manual would not be a "Networking Manual" so if you do not understand things like RSTP. LACP. Static LAG and such simple Google them as we followed the standards.
sdwisp
Tue Aug 25, 2015 7:35 pm
Chris as a Netoniz new-bee I was looking for the screen shoot and config examples so that I don't let the smoke out. The provided paper work in the switch box is telling me to looks for "The Basics and Examples" on your forum. I searched with no luck. Do you have screen shoots and Examples ? Lost a TS 5 today so I;m hopping to replace all my "not so tough switch" very soon. Thanks for the help :headb: :headb: :headb:
Eric Williams
619-468-9600
SDWISP
Tue Aug 25, 2015 8:02 pm
This is the post that is an example of a setup:
viewtopic.php?f=17&t=237
Here is another:
viewtopic.php?f=30&t=452
The only way your going to let smoke out is doing something foolish like one of the following:
1) Turning the wrong POE voltage on for a port, you have the following options
24V - For airMAX radios and
24V - AF5X, AF3X, AF2X (short cable runs)
48V - For Titaniums and 802.3af/at devices like cameras and phones
24VH - Available on some models for long cable runs for AF2X, AF3X, AF5X
48VH - AF24, AF24HD, AF5, MIMOSA and other high power links - BE 100% SURE BEFORE YOU TURN IT ON
2) Turning POE on to a port with a wire with a short in it so run a cable diagnostics first
3) If using a DC switch do NOT hook the polarity up backwards
If you setup TS5 and TS8 you should be able to setup a WISP Switch with no problems
If you have a specific question then ask it here on the forums.
On the Ports Tab I think everything is self explanatory but ask me if you have a question.
We do not have a manual yet but we made the UI EXTREMELY SIMPLE.
There are no setting on the Status Tab.
sdwisp
Wed Aug 26, 2015 11:11 am
Thanks Chris Thats what I was looking for :hurray: :hurray: :hurray:
Eric Williams
619-468-9600
SDWISP
Return to Sirhc's Corner
