WS-26-500-DC Reboots cold watchdog
wirelesscon
Has thanked: 4 times
Been thanked: 4 times
Tue Oct 27, 2026 7:12 pm
Folks,
we have 2 towers within 500m of each other on a site, one one tower we have WS-26-500-DC connected via 2 Fiber links in a LACP (FAST timer) (active ) LAG to a UBNT Edge switch with with 2 Fiber ports in a Port-Channel (fast timer)
the WS-26-500-DC is also connected to a RB1100AH via 3x 1G ports in a LAG to a Mikrotik Bonding interface (802.3.ad) with LACP 1 second timer,
we are running 1.5.26 and 1.5.27
the first switch was running 1.5.26 and then the switch was upgraded to 1.5.27, the second switch (replacing after the issue continued) started to reboot when I re-setup the LAG between the two Switches
we have had issues this morning we replaced the switch and when I enabled the second port-channel / LAG group between the edge switch and the WS-26-500-DC, the system seemed to reboot due to a watchdog (cold), after it,
I think that having 2x LACP LAgs with fast itmers can cause an issue and cause a watchdog reset,
can a watchdog timer be delayed for about 10 -15 minutes after a boot up to allow for remote diagnostics... the reboot loops can be very very painful
Tom Smyth
wirelesscon
Re: WS-26-500-DC Reboots cold watchdog
Tue Oct 27, 2026 7:46 pm
Jan 1 00:00:06 admin: stopped ntp daemon
Jan 1 00:00:06 admin: started ntp daemon
Jan 1 00:00:07 admin: sync time via ntp
Jan 1 00:00:12 system: Setting MAC address from flash configuration: EC:13:B2:06:AA:52
Jan 1 00:00:14 admin: stopped ntp daemon
Jan 1 00:00:14 admin: started ntp daemon
Jan 1 00:00:15 admin: sync time via ntp
Jan 1 00:00:16 admin: adding lan (eth0.240) to firewall zone lan
Jan 1 00:00:17 dropbear[733]: Running in background
Jan 1 00:00:18 netonix: 1.5.26 on WS-26-500-DC
Jan 1 00:00:19 admin: Unable to query power supply
Jan 1 00:01:34 LACP: starting negotiation with partner 04-F4-1C-75-DE-50
Jan 1 00:01:34 LACP: starting negotiation with partner 68-D7-9A-4D-15-61
Jan 1 00:01:36 LACP: LACP changed state to Active on port 22 (key 10)
Jan 1 00:01:36 LACP: LACP changed state to Active on port 25 (key 6)
Jan 1 00:01:36 LACP: LACP changed state to Active on port 21 (key 10)
Jan 1 00:01:47 SFP: I2C communication down to SFP 0, attempting to establish communications
Jan 1 00:01:48 Port: link state changed to 'up' (1G) on port 25
Jan 1 00:01:48 LACP: LACP changed state to Not active on port 25 (key 6)
Jan 1 00:01:49 switch[1005]: LACP changed state to Not active on port 25 (IEKENT02-sfp1-port9) (key 6)
Jan 1 00:01:49 LACP: starting negotiation with partner 68-D7-9A-4D-15-61
Jan 1 00:01:51 LACP: LACP changed state to Active on port 25 (key 6)
Jan 1 00:01:51 switch[1009]: LACP changed state to Active on port 25 (IEKENT02-sfp1-port9) (key 6)
Jan 1 00:01:55 SFP: I2C communication down to SFP 1, attempting to establish communications
Jan 1 00:02:11 sSMTP[1012]: Creating SSL connection to host
Jan 1 00:02:11 sSMTP[1012]: SSL connection using ECDHE-RSA-AES256-GCM-SHA384
Jan 1 00:02:12 sSMTP[1012]: Sent mail for r[redacted] (221 2.0.0 Bye) uid=0 username=admin outbytes=556
Jan 1 00:02:19 sSMTP[1008]: Creating SSL connection to host
Jan 1 00:02:19 sSMTP[1008]: SSL connection using ECDHE-RSA-AES256-GCM-SHA384
Jan 1 00:02:20 sSMTP[1008]: Sent mail for[redacted] (221 2.0.0 Bye) uid=0 username=admin outbytes=564
Jan 1 00:02:20 Port: link state changed to 'up' (1G) on port 25
Jan 1 00:02:20 LACP: LACP changed state to Not active on port 25 (key 6)
Jan 1 00:02:21 switch[1013]: LACP changed state to Not active on port 25 (IEKENT02-sfp1-port9) (key 6)
Jan 1 00:02:22 LACP: starting negotiation with partner 68-D7-9A-4D-15-61
Jan 1 00:02:23 LACP: LACP changed state to Active on port 25 (key 6)
Jan 1 00:02:23 switch[1017]: LACP changed state to Active on port 25 (IEKENT02-sfp1-port9) (key 6)
Jan 1 00:02:34 switch[1050]: Detected cold (watchdog) boot
Jan 1 00:02:35 Port: link state changed to 'down' on port 4
Jan 1 00:02:35 Port: link state changed to 'down' on port 2
Jan 1 00:02:35 Port: link state changed to 'down' on port 20
Jan 1 00:02:35 Port: link state changed to 'down' on port 1
Jan 1 00:02:35 Port: link state changed to 'down' on port 8
Jan 1 00:02:35 Port: link state changed to 'down' on port 10
Jan 1 00:02:35 Port: link state changed to 'down' on port 12
Jan 1 00:02:35 Port: link state changed to 'down' on port 9
Jan 1 00:02:35 switch[1050]: PoE enabled on port 1, PoE Smart is starting cable check
Jan 1 00:02:35 Port: link state changed to 'down' on port 19
Jan 1 00:02:35 Port: link state changed to 'down' on port 21
Jan 1 00:02:35 Port: link state changed to 'down' on port 22
Jan 1 00:02:35 LACP: LACP changed state to Not active on port 21 (key 10)
Jan 1 00:02:35 switch[1050]: PoE enabled on port 2, PoE Smart is starting cable check
Jan 1 00:02:35 LACP: LACP changed state to Not active on port 22 (key 10)
Jan 1 00:02:36 switch[1050]: PoE enabled on port 4, PoE Smart is starting cable check
Jan 1 00:02:36 switch[1056]: LACP changed state to Not active on port 22 (Concentrator-ether6) (key 10)
Jan 1 00:02:36 switch[1051]: LACP changed state to Not active on port 21 (Concentrator-ether13-poe) (key 10)
Jan 1 00:02:36 switch[1050]: PoE enabled on port 7, PoE Smart is starting cable check
Jan 1 00:02:36 switch[1050]: PoE enabled on port 8, PoE Smart is starting cable check
Jan 1 00:02:36 switch[1050]: PoE enabled on port 9, PoE Smart is starting cable check
Jan 1 00:02:36 switch[1050]: PoE enabled on port 10, PoE Smart is starting cable check
Jan 1 00:02:37 switch[1050]: PoE enabled on port 11, PoE Smart is starting cable check
Jan 1 00:02:37 switch[1050]: PoE enabled on port 12, PoE Smart is starting cable check
Jan 1 00:02:37 switch[1050]: PoE enabled on port 21, PoE Smart is starting cable check
Jan 1 00:02:37 Port: link state changed to 'up' (1G) on port 25
Jan 1 00:02:37 LACP: LACP changed state to Not active on port 25 (key 6)
Jan 1 00:02:38 switch[1084]: LACP changed state to Not active on port 25 (IEKENT02-sfp1-port9) (key 6)
Jan 1 00:02:38 admin: stopped ntp daemon
Jan 1 00:02:38 admin: started ntp daemon
Jan 1 00:02:38 admin: sync time via ntp
Jan 1 00:02:39 LACP: starting negotiation with partner 68-D7-9A-4D-15-61
Jan 1 00:02:40 LACP: LACP changed state to Active on port 25 (key 6)
Jan 1 00:02:40 switch[1113]: LACP changed state to Active on port 25 (IEKENT02-sfp1-port9) (key 6)
Jan 1 00:02:40 switch[1050]: Port 1 cable check results: Open, Abnormal termination, Open, Open
Jan 1 00:02:40 switch[1050]: Port 1 passed PoE Smart cable check, turning on power
Jan 1 00:02:40 switch[1050]: Port 2 cable check results: Abnormal termination, Abnormal termination, Abnormal termination, Abnormal termination
Jan 1 00:02:40 switch[1050]: Port 2 passed PoE Smart cable check, turning on power
Jan 1 00:02:40 switch[1050]: Port 4 cable check results: Abnormal termination, Abnormal termination, Open, Open
Jan 1 00:02:40 switch[1050]: Port 4 passed PoE Smart cable check, turning on power
Jan 1 00:02:41 switch[1050]: Port 7 cable check results: Open, Open, Open, Open
Jan 1 00:02:41 switch[1050]: Port 7 passed PoE Smart cable check, turning on power
Jan 1 00:02:41 switch[1050]: Port 8 cable check results: Open, Open, Open, Ok
Jan 1 00:02:41 switch[1050]: Port 8 passed PoE Smart cable check, turning on power
Jan 1 00:02:41 switch[1050]: Port 9 cable check results: Open, Open, Open, Open
Jan 1 00:02:41 switch[1050]: Port 9 passed PoE Smart cable check, turning on power
Jan 1 00:02:41 switch[1050]: Port 10 cable check results: Open, Open, Open, Open
Jan 1 00:02:41 switch[1050]: Port 10 passed PoE Smart cable check, turning on power
Jan 1 00:02:41 switch[1050]: Port 11 cable check results: Open, Open, Open, Open
Jan 1 00:02:41 switch[1050]: Port 11 passed PoE Smart cable check, turning on power
Jan 1 00:02:42 switch[1050]: Port 12 cable check results: Abnormal termination, Open, Open, Open
Jan 1 00:02:42 switch[1050]: Port 12 passed PoE Smart cable check, turning on power
Jan 1 00:02:42 switch[1050]: Port 21 cable check results: Open, Open, Open, Open
Jan 1 00:02:42 switch[1050]: Port 21 passed PoE Smart cable check, turning on power
Copyright 2014-2024 Netonix --- Firmware Version: 1.5.26
wirelesscon
Tue Oct 27, 2026 7:49 pm
Jan 1 00:00:06 admin: sync time via ntp
Jan 1 00:00:12 system: Setting MAC address from flash configuration: EC:13:B2:06:3F:94
Jan 1 00:00:14 admin: sync time via ntp
Jan 1 00:00:16 dropbear[734]: Running in background
Jan 1 00:00:18 netonix: 1.5.27 on WS-26-500-DC
Jan 1 00:00:31 LACP: starting negotiation with partner 04-F4-1C-75-DE-50
Jan 1 00:00:31 LACP: starting negotiation with partner 68-D7-9A-4D-15-61
Jan 1 00:00:31 Port: link state changed to 'up' (1G) on port 26
Jan 1 00:00:33 LACP: LACP changed state to Active on port 22 (key 10)
Jan 1 00:00:33 LACP: LACP changed state to Active on port 19 (key 10)
Jan 1 00:00:33 LACP: LACP changed state to Active on port 20 (key 10)
Jan 1 00:00:34 LACP: LACP changed state to Active on port 21 (key 10)
Jan 1 00:00:34 LACP: LACP changed state to Active on port 26 (key 5)
Jan 1 00:00:34 LACP: LACP changed state to Active on port 25 (key 5)
Jan 1 00:00:38 Port: link state changed to 'down' on port 25
Jan 1 00:00:38 LACP: LACP changed state to Not active on port 25 (key 5)
Jan 1 00:00:38 switch[1002]: LACP changed state to Not active on port 25 (IEKENT02-sfp1-port9) (key 5)
Jan 1 00:00:39 Port: link state changed to 'up' (1G) on port 25
Jan 1 00:00:39 Port: link state changed to 'up' (1G) on port 26
Jan 1 00:00:39 LACP: LACP changed state to Not active on port 26 (key 5)
Jan 1 00:00:39 switch[1008]: LACP changed state to Not active on port 26 (IEKENT02-sfp2-port10) (key 5)
Jan 1 00:00:39 LACP: starting negotiation with partner 68-D7-9A-4D-15-61
Jan 1 00:00:40 Port: link state changed to 'up' (1G) on port 25
Jan 1 00:00:40 Port: link state changed to 'up' (1G) on port 26
Jan 1 00:00:40 LACP: starting negotiation with partner 68-D7-9A-4D-15-61
Jan 1 00:00:42 Port: link state changed to 'down' on port 26
Jan 1 00:00:42 LACP: LACP changed state to Active on port 25 (key 5)
Jan 1 00:00:43 switch[1012]: LACP changed state to Active on port 25 (IEKENT02-sfp1-port9) (key 5)
Jan 1 00:00:43 Port: link state changed to 'up' (1G) on port 26
Jan 1 00:00:46 Port: link state changed to 'up' (1G) on port 26
Jan 1 00:00:48 LACP: LACP changed state to Active on port 26 (key 5)
Jan 1 00:00:49 switch[1018]: LACP changed state to Active on port 26 (IEKENT02-sfp2-port10) (key 5)
Jan 1 00:00:54 Port: link state changed to 'up' (1G) on port 26
Jan 1 00:00:54 LACP: LACP changed state to Not active on port 26 (key 5)
Jan 1 00:00:54 switch[1022]: LACP changed state to Not active on port 26 (IEKENT02-sfp2-port10) (key 5)
Jan 1 00:00:54 sSMTP[1025]: Creating SSL connection to host
Jan 1 00:00:55 sSMTP[1025]: SSL connection using ECDHE-RSA-AES256-GCM-SHA384
Jan 1 00:00:56 sSMTP[1025]: Sent mail for admin@wirelessconnect.eu (221 2.0.0 Bye) uid=0 username=admin outbytes=566
Jan 1 00:00:59 sSMTP[1005]: Creating SSL connection to host
Jan 1 00:00:59 sSMTP[1005]: SSL connection using ECDHE-RSA-AES256-GCM-SHA384
Jan 1 00:00:59 sSMTP[1021]: Creating SSL connection to host
Jan 1 00:00:59 Port: link state changed to 'up' (1G) on port 26
Jan 1 00:00:59 sSMTP[1021]: SSL connection using ECDHE-RSA-AES256-GCM-SHA384
Jan 1 00:01:00 sSMTP[1011]: Creating SSL connection to host
Jan 1 00:01:00 sSMTP[1011]: SSL connection using ECDHE-RSA-AES256-GCM-SHA384
Jan 1 00:01:00 sSMTP[1005]: Sent mail for admin@wirelessconnect.eu (221 2.0.0 Bye) uid=0 username=admin outbytes=564
Jan 1 00:01:00 sSMTP[1021]: Sent mail for admin@wirelessconnect.eu (221 2.0.0 Bye) uid=0 username=admin outbytes=558
Jan 1 00:01:01 sSMTP[1011]: Sent mail for admin@wirelessconnect.eu (221 2.0.0 Bye) uid=0 username=admin outbytes=566
Jan 1 00:01:03 sSMTP[1015]: Creating SSL connection to host
Jan 1 00:01:03 sSMTP[1015]: SSL connection using ECDHE-RSA-AES256-GCM-SHA384
Jan 1 00:01:03 Port: link state changed to 'down' on port 26
Jan 1 00:01:04 sSMTP[1015]: Sent mail for admin@wirelessconnect.eu (221 2.0.0 Bye) uid=0 username=admin outbytes=556
Jan 1 00:01:04 Port: link state changed to 'up' (1G) on port 26
Jan 1 00:01:06 LACP: LACP changed state to Active on port 26 (key 5)
Jan 1 00:01:07 switch[1026]: LACP changed state to Active on port 26 (IEKENT02-sfp2-port10) (key 5)
Jan 1 00:01:07 sSMTP[1029]: Creating SSL connection to host
Jan 1 00:01:07 sSMTP[1029]: SSL connection using ECDHE-RSA-AES256-GCM-SHA384
Jan 1 00:01:08 sSMTP[1029]: Sent mail for admin@wirelessconnect.eu (221 2.0.0 Bye) uid=0 username=admin outbytes=558
Jan 1 00:01:11 Port: link state changed to 'up' (1G) on port 26
Jan 1 00:01:11 LACP: LACP changed state to Not active on port 26 (key 5)
Jan 1 00:01:11 switch[1030]: LACP changed state to Not active on port 26 (IEKENT02-sfp2-port10) (key 5)
Jan 1 00:01:12 sSMTP[1033]: Creating SSL connection to host
Jan 1 00:01:12 sSMTP[1033]: SSL connection using ECDHE-RSA-AES256-GCM-SHA384
Jan 1 00:01:13 sSMTP[1033]: Sent mail for [redacted] (221 2.0.0 Bye) uid=0 username=admin outbytes=566
Jan 1 00:01:15 Port: link state changed to 'up' (1G) on port 26
Jan 1 00:01:19 Port: link state changed to 'up' (1G) on port 26
Jan 1 00:01:21 LACP: LACP changed state to Active on port 26 (key 5)
Jan 1 00:01:22 switch[1034]: LACP changed state to Active on port 26 (IEKENT02-sfp2-port10) (key 5)
Jan 1 00:01:22 sSMTP[1037]: Creating SSL connection to host
Jan 1 00:01:22 sSMTP[1037]: SSL connection using ECDHE-RSA-AES256-GCM-SHA384
Jan 1 00:01:23 sSMTP[1037]: Sent mail for [redacted ] (221 2.0.0 Bye) uid=0 username=admin outbytes=558
Jan 1 00:01:28 Port: link state changed to 'up' (1G) on port 26
Jan 1 00:01:28 LACP: LACP changed state to Not active on port 26 (key 5)
Jan 1 00:01:28 switch[1038]: LACP changed state to Not active on port 26 (IEKENT02-sfp2-port10) (key 5)
Jan 1 00:01:29 sSMTP[1041]: Creating SSL connection to host
Jan 1 00:01:29 sSMTP[1041]: SSL connection using ECDHE-RSA-AES256-GCM-SHA384
Jan 1 00:01:29 Port: link state changed to 'down' on port 26
Jan 1 00:01:30 Port: link state changed to 'up' (1G) on port 26
Jan 1 00:01:30 sSMTP[1041]: Sent mail for [redacted ](221 2.0.0 Bye) uid=0 username=admin outbytes=566
Jan 1 00:01:31 switch[1071]: Detected cold (watchdog) boot
Jan 1 00:01:31 switch[1070]: temp sensor version 3
Jan 1 00:01:32 Port: link state changed to 'down' on port 20
Jan 1 00:01:32 Port: link state changed to 'down' on port 22
Jan 1 00:01:32 Port: link state changed to 'down' on port 3
Jan 1 00:01:32 Port: link state changed to 'down' on port 1
Jan 1 00:01:32 Port: link state changed to 'down' on port 7
Jan 1 00:01:32 LACP: LACP changed state to Not active on port 20 (key 10)
Jan 1 00:01:32 switch[1071]: PoE enabled on port 1, PoE Smart is starting cable check
Jan 1 00:01:32 LACP: LACP changed state to Not active on port 22 (key 10)
Jan 1 00:01:33 switch[1071]: PoE enabled on port 2, PoE Smart is starting cable check
Jan 1 00:01:33 Port: link state changed to 'down' on port 8
Jan 1 00:01:33 Port: link state changed to 'down' on port 19
Jan 1 00:01:33 switch[1071]: PoE enabled on port 3, PoE Smart is starting cable check
Jan 1 00:01:33 Port: link state changed to 'down' on port 21
Jan 1 00:01:33 LACP: LACP changed state to Not active on port 19 (key 10)
Jan 1 00:01:33 switch[1071]: PoE enabled on port 4, PoE Smart is starting cable check
Jan 1 00:01:33 switch[1074]: LACP changed state to Not active on port 22 (AC01-ether6) (key 10)
Jan 1 00:01:33 LACP: LACP changed state to Not active on port 21 (key 10)
Jan 1 00:01:33 switch[1071]: PoE enabled on port 7, PoE Smart is starting cable check
Jan 1 00:01:33 switch[1071]: PoE enabled on port 8, PoE Smart is starting cable check
Jan 1 00:01:34 switch[1072]: LACP changed state to Not active on port 20 (AC01-ether1) (key 10)
Jan 1 00:01:34 Port: link state changed to 'down' on port 4
Jan 1 00:01:34 switch[1071]: PoE enabled on port 9, PoE Smart is starting cable check
Jan 1 00:01:34 switch[1071]: PoE enabled on port 10, PoE Smart is starting cable check
Jan 1 00:01:34 switch[1071]: PoE enabled on port 12, PoE Smart is starting cable check
Jan 1 00:01:34 LACP: LACP changed state to Active on port 26 (key 5)
Jan 1 00:01:34 switch[1071]: PoE enabled on port 21, PoE Smart is starting cable check
Jan 1 00:01:35 switch[1079]: LACP changed state to Not active on port 19 (AC01-ether2) (key 10)
Jan 1 00:01:35 switch[1082]: LACP changed state to Not active on port 21 (AC01-ether13-poe) (key 10)
Jan 1 00:01:35 switch[1097]: LACP changed state to Active on port 26 (IEKENT02-sfp2-port10) (key 5)
Jan 1 00:01:37 admin: stopped ntp daemon
Jan 1 00:01:37 admin: started ntp daemon
Jan 1 00:01:37 admin: sync time via ntp
Jan 1 00:01:37 switch[1071]: Port 1 cable check results: Open, Abnormal termination, Open, Open
Jan 1 00:01:37 switch[1071]: Port 1 passed PoE Smart cable check, turning on power
Jan 1 00:01:37 switch[1071]: Port 2 cable check results: Abnormal termination, Abnormal termination, Abnormal termination, Abnormal termination
Jan 1 00:01:37 switch[1071]: Port 2 passed PoE Smart cable check, turning on power
Jan 1 00:01:38 switch[1071]: Port 3 cable check results: Abnormal termination, Open, Abnormal termination, Open
Jan 1 00:01:38 switch[1071]: Port 3 passed PoE Smart cable check, turning on power
Jan 1 00:01:38 switch[1071]: Port 4 cable check results: Abnormal termination, Abnormal termination, Open, Open
Jan 1 00:01:38 switch[1071]: Port 4 passed PoE Smart cable check, turning on power
Jan 1 00:01:38 switch[1071]: Port 7 cable check results: Open, Open, Abnormal termination, Abnormal termination
Jan 1 00:01:38 switch[1071]: Port 7 passed PoE Smart cable check, turning on power
Jan 1 00:01:38 switch[1071]: Port 8 cable check results: Open, Open, Open, Open
Jan 1 00:01:38 switch[1071]: Port 8 passed PoE Smart cable check, turning on power
Jan 1 00:01:39 switch[1071]: Port 9 cable check results: Open, Open, Open, Open
Jan 1 00:01:39 switch[1071]: Port 9 passed PoE Smart cable check, turning on power
Jan 1 00:01:39 switch[1071]: Port 10 cable check results: Open, Open, Open, Open
Jan 1 00:01:39 switch[1071]: Port 10 passed PoE Smart cable check, turning on power
Jan 1 00:01:39 switch[1071]: Port 12 cable check results: Open, Open, Open, Open
Jan 1 00:01:39 switch[1071]: Port 12 passed PoE Smart cable check, turning on power
Jan 1 00:01:39 switch[1071]: Port 21 cable check results: Open, Open, Open, Open
Jan 1 00:01:39 switch[1071]: Port 21 passed PoE Smart cable check, turning on power
Jan 1 00:01:41 Port: link state changed to 'up' (1G) on port 1
Jan 1 00:01:41 Port: link state changed to 'up' (1G) on port 7
Jan 1 00:01:41 Port: link state changed to 'up' (1G) on port 8
Jan 1 00:01:48 Port: link state changed to 'down' on port 8
Jan 1 00:01:51 Port: link state changed to 'up' (10M-H) on port 2
Jan 1 00:01:58 Port: link state changed to 'up' (1G) on port 4
Jan 1 00:01:59 Port: link state changed to 'up' (1G) on port 3
Jan 1 00:02:01 Port: link state changed to 'down' on port 2
Jan 1 00:02:04 Port: link state changed to 'up' (1G) on port 2
Jan 1 00:02:06 Port: link state changed to 'down' on port 1
Jan 1 00:02:06 Port: link state changed to 'down' on port 7
Jan 1 00:02:07 Port: link state changed to 'up' (10M-H) on port 1
Jan 1 00:02:08 Port: link state changed to 'up' (10M-H) on port 7
Jan 1 00:02:14 Port: link state changed to 'down' on port 1
Jan 1 00:02:16 Port: link state changed to 'down' on port 7
Jan 1 00:02:27 Port: link state changed to 'up' (1G) on port 19
Jan 1 00:02:28 LACP: starting negotiation with partner 04-F4-1C-75-DE-50
Jan 1 00:02:29 Port: link state changed to 'up' (1G) on port 20
Jan 1 00:02:30 Port: link state changed to 'up' (1G) on port 22
Jan 1 00:02:31 LACP: LACP changed state to Active on port 19 (key 10)
Jan 1 00:02:31 switch[1353]: LACP changed state to Active on port 19 (AC01-ether2) (key 10)
Jan 1 00:02:31 Port: link state changed to 'up' (1G) on port 21
Jan 1 00:02:31 LACP: LACP changed state to Active on port 20 (key 10)
Jan 1 00:02:32 switch[1357]: LACP changed state to Active on port 20 (AC01-ether1) (key 10)
Jan 1 00:02:32 LACP: LACP changed state to Active on port 22 (key 10)
Jan 1 00:02:33 switch[1363]: LACP changed state to Active on port 22 (AC01-ether6) (key 10)
Jan 1 00:02:34 Port: link state changed to 'up' (1G) on port 1
Jan 1 00:02:35 LACP: LACP changed state to Active on port 21 (key 10)
Jan 1 00:02:36 switch[1367]: LACP changed state to Active on port 21 (AC01-ether13-poe) (key 10)
Jan 1 00:02:46 switch[1053]: Warning: expected 3 fans but found 2
Copyright 2014-2024 Netonix --- Firmware Version: 1.5.27
wirelesscon
Tue Oct 27, 2026 7:52 pm
Jan 1 00:01:00 Port: link state changed to 'down' on port 7
Jan 1 00:01:30 switch[1033]: Detected cold (watchdog) boot
Jan 1 00:01:30 switch[1032]: temp sensor version 3
Jan 1 00:01:31 switch[1033]: PoE enabled on port 1, PoE Smart is starting cable check
Jan 1 00:01:31 switch[1033]: PoE enabled on port 2, PoE Smart is starting cable check
Jan 1 00:01:31 switch[1033]: PoE enabled on port 3, PoE Smart is starting cable check
Jan 1 00:01:32 switch[1033]: PoE enabled on port 4, PoE Smart is starting cable check
Jan 1 00:01:32 switch[1033]: PoE enabled on port 7, PoE Smart is starting cable check
Jan 1 00:01:32 switch[1033]: PoE enabled on port 8, PoE Smart is starting cable check
Jan 1 00:01:32 switch[1033]: PoE enabled on port 9, PoE Smart is starting cable check
Jan 1 00:01:32 switch[1033]: PoE enabled on port 10, PoE Smart is starting cable check
Jan 1 00:01:32 switch[1033]: PoE enabled on port 12, PoE Smart is starting cable check
Jan 1 00:01:32 switch[1033]: PoE enabled on port 21, PoE Smart is starting cable check
Jan 1 00:01:34 admin: stopped ntp daemon
Jan 1 00:01:34 admin: started ntp daemon
Jan 1 00:01:34 admin: sync time via ntp
Jan 1 00:01:36 switch[1033]: Port 1 cable check results: Open, Open, Open, Open
Jan 1 00:01:36 switch[1033]: Port 1 passed PoE Smart cable check, turning on power
Jan 1 00:01:36 switch[1033]: Port 2 cable check results: Open, Open, Open, Open
Jan 1 00:01:36 switch[1033]: Port 2 passed PoE Smart cable check, turning on power
Jan 1 00:01:36 switch[1033]: Port 3 cable check results: Open, Open, Open, Open
Jan 1 00:01:36 switch[1033]: Port 3 passed PoE Smart cable check, turning on power
Jan 1 00:01:37 switch[1033]: Port 4 cable check results: Open, Open, Open, Open
Jan 1 00:01:37 switch[1033]: Port 4 passed PoE Smart cable check, turning on power
Jan 1 00:01:37 switch[1033]: Port 7 cable check results: Open, Open, Open, Open
Jan 1 00:01:37 switch[1033]: Port 7 passed PoE Smart cable check, turning on power
Jan 1 00:01:37 switch[1033]: Port 8 cable check results: Open, Open, Open, Open
Jan 1 00:01:37 switch[1033]: Port 8 passed PoE Smart cable check, turning on power
Jan 1 00:01:37 switch[1033]: Port 9 cable check results: Open, Open, Open, Open
Jan 1 00:01:37 switch[1033]: Port 9 passed PoE Smart cable check, turning on power
Jan 1 00:01:37 switch[1033]: Port 10 cable check results: Open, Open, Open, Open
Jan 1 00:01:37 switch[1033]: Port 10 passed PoE Smart cable check, turning on power
Jan 1 00:01:37 switch[1033]: Port 12 cable check results: Open, Open, Open, Open
Jan 1 00:01:37 switch[1033]: Port 12 passed PoE Smart cable check, turning on power
Jan 1 00:01:37 switch[1033]: Port 21 cable check results: Open, Open, Open, Open
Jan 1 00:01:37 switch[1033]: Port 21 passed PoE Smart cable check, turning on power
Jan 1 00:01:40 switch[1015]: Warning: expected 3 fans but found 2
Jan 1 00:02:26 Port: link state changed to 'up' (1G) on port 19
Jan 1 00:02:26 Port: link state changed to 'up' (1G) on port 20
Jan 1 00:02:27 LACP: starting negotiation with partner 04-F4-1C-75-DE-50
Jan 1 00:02:28 Port: link state changed to 'up' (1G) on port 22
Jan 1 00:02:29 LACP: LACP changed state to Active on port 19 (key 10)
Jan 1 00:02:29 LACP: LACP changed state to Active on port 20 (key 10)
Jan 1 00:02:29 Port: link state changed to 'up' (1G) on port 21
Jan 1 00:02:31 LACP: LACP changed state to Active on port 22 (key 10)
Jan 1 00:02:34 LACP: LACP changed state to Active on port 21 (key 10)
Jan 1 00:03:17 UI[975]: Configuration changed by admin (10.130.64.201)
Jan 1 00:03:17 UI[975]: Config_Version: 391 => 392
Jan 1 00:03:17 UI[975]: PORT 21 PoE: 48V => Off
Jan 1 00:03:19 Port: link state changed to 'down' on port 20
Jan 1 00:03:19 Port: link state changed to 'down' on port 21
Jan 1 00:03:19 LACP: LACP changed state to Not active on port 20 (key 10)
Jan 1 00:03:20 LACP: LACP changed state to Not active on port 21 (key 10)
Jan 1 00:03:20 Port: link state changed to 'down' on port 19
Jan 1 00:03:20 Port: link state changed to 'down' on port 22
Jan 1 00:03:20 LACP: LACP changed state to Not active on port 19 (key 10)
Jan 1 00:03:20 LACP: LACP changed state to Not active on port 22 (key 10)
Jan 1 00:03:20 switch[1524]: LACP changed state to Not active on port 20 (AC01-ether1) (key 10)
Jan 1 00:03:20 switch[1525]: LACP changed state to Not active on port 21 (AC01-ether13-poe) (key 10)
Jan 1 00:03:21 switch[1526]: LACP changed state to Not active on port 19 (AC01-ether2) (key 10)
Jan 1 00:03:21 switch[1527]: LACP changed state to Not active on port 22 (AC01-ether6) (key 10)
Jan 1 00:03:36 UI[975]: Configuration changed by admin (10.130.64.201)
Jan 1 00:03:36 UI[975]: Config_Version: 392 => 393
Jan 1 00:03:36 UI[975]: PORT 21 PoE: Off => 24V
Jan 1 00:03:37 switch[1033]: PoE enabled on port 21, PoE Smart is starting cable check
Jan 1 00:03:41 sSMTP[1099]: Unable to locate [redacted]
Jan 1 00:03:41 sSMTP[1099]: Cannot open [redacted]:25
Jan 1 00:03:42 switch[1033]: Port 21 cable check results: Open, Open, Open, Open
Jan 1 00:03:42 switch[1033]: Port 21 passed PoE Smart cable check, turning on power
Jan 1 00:04:30 Port: link state changed to 'up' (1G) on port 19
Jan 1 00:04:30 Port: link state changed to 'up' (1G) on port 20
Jan 1 00:04:32 LACP: starting negotiation with partner 04-F4-1C-75-DE-50
Jan 1 00:04:33 Port: link state changed to 'up' (1G) on port 22
Jan 1 00:04:34 Port: link state changed to 'up' (1G) on port 21
Jan 1 00:04:34 LACP: LACP changed state to Active on port 19 (key 10)
Jan 1 00:04:34 LACP: LACP changed state to Active on port 20 (key 10)
Jan 1 00:04:34 switch[1827]: LACP changed state to Active on port 19 (AC01-ether2) (key 10)
Jan 1 00:04:35 switch[1828]: LACP changed state to Active on port 20 (AC01-ether1) (key 10)
Jan 1 00:04:38 LACP: LACP changed state to Active on port 22 (key 10)
Jan 1 00:04:38 switch[1849]: LACP changed state to Active on port 22 (AC01-ether6) (key 10)
Jan 1 00:04:39 LACP: LACP changed state to Active on port 21 (key 10)
Jan 1 00:04:39 switch[1853]: LACP changed state to Active on port 21 (AC01-ether13-poe) (key 10)
Jan 1 00:05:21 sSMTP[1536]: Unable to locate [redacted]
Jan 1 00:05:21 sSMTP[1536]: Cannot open [redacted]:25
Jan 1 00:05:22 sSMTP[1539]: Unable to locate [redacted]
Jan 1 00:05:22 sSMTP[1539]: Cannot open [redacted]:25
Jan 1 00:05:22 sSMTP[1547]: Unable to locate [redacted]
Jan 1 00:05:22 sSMTP[1547]: Cannot open [redacted]:25
Jan 1 00:05:22 sSMTP[1546]: Unable to locate [redacted]
Jan 1 00:05:22 sSMTP[1546]: Cannot open [redacted]:25
Jan 1 00:06:35 sSMTP[1831]: Unable to locate [redacted]
Jan 1 00:06:35 sSMTP[1831]: Cannot open [redacted]:25
Jan 1 00:06:35 sSMTP[1836]: Unable to locate [redacted]
Jan 1 00:06:35 sSMTP[1836]: Cannot open [redacted]:25
Jan 1 00:06:39 sSMTP[1852]: Unable to locate [redacted]
Jan 1 00:06:39 sSMTP[1852]: Cannot open [redacted]:25
Jan 1 00:06:40 sSMTP[1858]: Unable to locate [redacted]
Jan 1 00:06:40 sSMTP[1858]: Cannot open [redacted]:25
