I was working on one of our Netonix devices and noticed an IP loop. I changed the gateway on the Netonix, but incorrectly and now I have no access back into the equipment.
the device is configured with a static IP xx.xx.xx.90 , netmask 255.255.255.252, Gateway xx.xx.xx.88. The gateway should be .89. I cannot find a way to get back into this device without factory resetting to fix this address. The device is currently in use though, It still functions as intended, just no access to get in.
What would be the best way to get back into our Netonix switch, preferably without needing to factory reset and reprogram.
Locked out of Netonix, bad gateway address
- JacobHaley
Re: Locked out of Netonix, bad gateway address
ssh to xx.xx.xx.89 that should still be reachable and then, ssh to the netonix xx.xx.xx.90
