Switch Rebuild
shop@vicihorizon.com
Switch Rebuild
Tue May 02, 2023 9:54 am
I have 6, 8 port and 1, 12 port netonix switches I need to have rebuilt. Several have 1 or 2 ports that don't work in them and I'm sure the fans need replaced. How much would you estimate the cost on rebuilding them would be? Thanks Jason Keller Horizon Net
Re: Switch Rebuild
Tue May 02, 2023 9:59 am
First off, are all the switches still within the warranty period? Netonix will only do repairs on switches still under warranty.
For out-of-warranty work you might want to consider https://isptechnology.ca/
