AF 5X
rebelwireless
Has thanked: 31 times
Been thanked: 136 times
AF 5X
Thu Feb 05, 2015 6:35 pm
thoughts on the AF5X? I ordered a handful of them and the RD30 coversion kits. I'm thinking it was good to wait and not buy the RAC5PTP.
wayneorack
Has thanked: 188 times
Been thanked: 64 times
Re: AF 5X
Thu Feb 05, 2015 6:53 pm
How much signal loss will the RAC5PTP introduce?
Edit: How much signal loss will the RD30 conversion kit introduce?
Sorry, it has been a long day....
rebelwireless
Re: AF 5X
Thu Feb 05, 2015 7:04 pm
wayneorack wrote:How much signal loss will the RAC5PTP introduce?
? clarify please
wayneorack
Re: AF 5X
Thu Feb 05, 2015 7:14 pm
rebelwireless
Re: AF 5X
Thu Feb 05, 2015 7:20 pm
wayneorack wrote:How much signal loss will the RD30 conversion kit introduce?
The conversion kit is a replacement feed horn mount tilted 45 degrees. Many of the beta testers used this specific combo w/ great results. I expect over 250Mbps one away at 12 miles, if not over 300.
wayneorack
Re: AF 5X
Thu Feb 05, 2015 7:40 pm
Looks like to me the conversion kit adds some more connectors and coax. I may be wrong. I hope so.
I didnt mean to derail the thread. I am very excited about this product and cant wait to put some in operation.
rebelwireless
Re: AF 5X
Thu Feb 05, 2015 7:54 pm
wayneorack wrote:Looks like to me the conversion kit adds some more connectors and coax. I may be wrong. I hope so.
it just turns the two rp-sma plugs so that they don't bump the feed. The third is the GPS receiver port.
Been thanked: 1362 times
Re: AF 5X
Thu Feb 05, 2015 9:22 pm
No loss added
coverts to slant 45 vs vertical horizontal
Creates 3dB Isolation from H/V polarity noise
wtm
Has thanked: 41 times
Been thanked: 36 times
Re: AF 5X
Fri Feb 06, 2015 12:44 am
Chris, per some posts on the UBNT forum regarding this product and the RF Armor shielding. Might not need to re-do the radio box?
The new radio is aluminum with heat sinks on it, and enclosing it in a box might overheat it. With the aluminum case on the radio, looks like it might be shielded enough. I would just suggest that the radio box be removed and use the supplied plastic covers (Now where did I put all those at?)
Of course, still definitely need the shielding on the front of the dish!
Wayne
Re: AF 5X
Fri Feb 06, 2015 1:12 am
Not sure what good or bad for RF and heat the box would be or if it fits in the box even
The NEWEST Dish Box being shipped since spring of last year are PROBABLY large enough but the older Dish boxes are NOT.
Return to airFIBER™
