Hi, I'm considering using ubiquiti sectors with shields but instead of a rocket i'm planning to use a mikrotik look-a-like.
The basebox is 13,5cm wide and the back shield is 13,75cm so i guess that it wold fit, but it's 18cm long and i dont have a clue if that thing so long would fit inside the back shield.
Does anyone certainly know if a 18cm long box would fit inside the back shield??
http://www.rfarmor.com/cart/index.php?m ... ducts_id=7
http://routerboard.com/RB912UAG-5HPnD-OUT
RFArmor with Mikrotik BaseBox
Forum rules
vicent_nb1 - Member
- Has thanked: 31 times
- Been thanked: 136 times
Re: RFArmor with Mikrotik BaseBox
I can't find the measurements of the box, but I don't think it will fit. Chris will need to chime in here.
I think it just fits in -barely
case is plastic, get a file and make it fit ;)
