Ports disabled after reboot with PoE Smart Disabled
LRL - Experienced Member
- Has thanked: 19 times
- Been thanked: 49 times
On one of my 12-250-DCs whenever I reboot it I have ports 4, 7, 9,11,12 show as being disabled in the status, but on the port tab the gui shows them as enabled. I've disabled PoE Smart and they still do that same thing, with out without radio on the ports.
-LRL
Re: Ports disabled after reboot with PoE Smart Disabled
To confirm this is the WS-12-250-DC?
What version of firmware?
What does the log say?
Latest version, no log entries regarding any ports except port1 which is my mgmt link.
- Code: Select all
Dec 31 17:00:03 syslogd started: BusyBox v1.19.4
Dec 31 17:00:03 kernel: klogd started: BusyBox v1.19.4 (2015-08-14 15:50:44 EDT)
Dec 31 17:00:03 kernel: Linux version 2.6.26.8 (dev@netonixdev) (gcc version 4.1.2) #9 Sat Feb 21 19:48:11 EST 2015
Dec 31 17:00:03 kernel: Invalid kernel arglist - use RedBoot "exec" command to boot kernel.
Dec 31 17:00:03 kernel: Using predefined kernel options.
Dec 31 17:00:03 kernel: CPU revision is: 02019654 (MIPS 24K)
Dec 31 17:00:03 kernel: Determined physical RAM map:
Dec 31 17:00:03 kernel: User-defined physical RAM map:
Dec 31 17:00:03 kernel: memory: 08000000 @ 00000000 (usable)
Dec 31 17:00:03 kernel: Entering add_active_range(0, 0, 32768) 0 entries of 256 used
Dec 31 17:00:03 kernel: Zone PFN ranges:
Dec 31 17:00:03 kernel: Normal 0 -> 32768
Dec 31 17:00:03 kernel: Movable zone start PFN for each node
Dec 31 17:00:03 kernel: early_node_map[1] active PFN ranges
Dec 31 17:00:03 kernel: 0: 0 -> 32768
Dec 31 17:00:03 kernel: On node 0 totalpages: 32768
Dec 31 17:00:03 kernel: Normal zone: 256 pages used for memmap
Dec 31 17:00:03 kernel: Normal zone: 0 pages reserved
Dec 31 17:00:03 kernel: Normal zone: 32512 pages, LIFO batch:7
Dec 31 17:00:03 kernel: Movable zone: 0 pages used for memmap
Dec 31 17:00:03 kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
Dec 31 17:00:03 kernel: Kernel command line: console=ttyS0,115200 init=/etc/preinit mem=128M
Dec 31 17:00:03 kernel: Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes.
Dec 31 17:00:03 kernel: Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
Dec 31 17:00:03 kernel: Writing ErrCtl register=80004000
Dec 31 17:00:03 kernel: Readback ErrCtl register=80004000
Dec 31 17:00:03 kernel: Cache parity protection enabled
Dec 31 17:00:03 kernel: PID hash table entries: 512 (order: 9, 2048 bytes)
Dec 31 17:00:04 kernel: Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Dec 31 17:00:04 kernel: Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Dec 31 17:00:04 kernel: Memory: 126052k/131072k available (1917k kernel code, 4840k reserved, 417k data, 116k init, 0k highmem)
Dec 31 17:00:04 kernel: SLUB: Genslabs=6, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Dec 31 17:00:04 kernel: Calibrating delay loop... 277.70 BogoMIPS (lpj=1388544)
Dec 31 17:00:04 kernel: Mount-cache hash table entries: 512
Dec 31 17:00:04 kernel: net_namespace: 640 bytes
Dec 31 17:00:04 kernel: NET: Registered protocol family 16
Dec 31 17:00:04 kernel: NET: Registered protocol family 2
Dec 31 17:00:04 kernel: Switched to high resolution mode on CPU 0
Dec 31 17:00:04 kernel: IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
Dec 31 17:00:04 kernel: TCP established hash table entries: 4096 (order: 3, 32768 bytes)
Dec 31 17:00:04 kernel: TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
Dec 31 17:00:04 kernel: TCP: Hash tables configured (established 4096 bind 4096)
Dec 31 17:00:04 kernel: TCP reno registered
Dec 31 17:00:04 kernel: squashfs: version 3.0 (2006/03/15) Phillip Lougher
Dec 31 17:00:04 kernel: Registering mini_fo version $Id$
Dec 31 17:00:04 kernel: JFFS2 version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
Dec 31 17:00:04 kernel: msgmni has been set to 246
Dec 31 17:00:04 kernel: io scheduler noop registered
Dec 31 17:00:04 kernel: io scheduler deadline registered (default)
Dec 31 17:00:04 kernel: Serial: 8250/16550 driver $Revision: 1.90 $ 1 ports, IRQ sharing disabled
Dec 31 17:00:04 kernel: serial8250.0: ttyS0 at MMIO 0x70100000 (irq = 14) is a 16550A
Dec 31 17:00:04 kernel: console [ttyS0] enabled
Dec 31 17:00:04 kernel: No NAND device found!!!
Dec 31 17:00:04 kernel: m25p80 spi0.0: m25p128 (16384 Kbytes)
Dec 31 17:00:04 kernel: Mapped SPI read area @0x40000000 len 16777216
Dec 31 17:00:04 kernel: Creating 10 MTD partitions on "m25p80":
Dec 31 17:00:04 kernel: 0x00000000-0x00040000 : "RedBoot"
Dec 31 17:00:04 kernel: 0x00040000-0x00080000 : "config"
Dec 31 17:00:04 kernel: 0x00080000-0x001c0000 : "linux_recovery"
Dec 31 17:00:04 kernel: 0x001c0000-0x003c0000 : "rootfs_recovery"
Dec 31 17:00:04 kernel: 0x003c0000-0x00500000 : "linux"
Dec 31 17:00:04 kernel: 0x00500000-0x00b00000 : "rootfs"
Dec 31 17:00:04 kernel: mtd: partition "rootfs" set to be root filesystem
Dec 31 17:00:04 kernel: 0x00b00000-0x00f40000 : "rootfs_data"
Dec 31 17:00:04 kernel: 0x00f40000-0x00f80000 : "FIS directory"
Dec 31 17:00:04 kernel: 0x00f80000-0x00f81000 : "RedBoot config"
Dec 31 17:00:04 kernel: 0x00fc0000-0x01000000 : "Redundant FIS"
Dec 31 17:00:04 kernel: ip_tables: (C) 2000-2006 Netfilter Core Team
Dec 31 17:00:04 kernel: TCP cubic registered
Dec 31 17:00:04 kernel: NET: Registered protocol family 10
Dec 31 17:00:04 kernel: lo: Disabled Privacy Extensions
Dec 31 17:00:04 kernel: ip6_tables: (C) 2000-2006 Netfilter Core Team
Dec 31 17:00:04 kernel: NET: Registered protocol family 17
Dec 31 17:00:04 kernel: 802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
Dec 31 17:00:04 kernel: All bugs added by David S. Miller <davem@redhat.com>
Dec 31 17:00:04 kernel: VFS: Mounted root (squashfs filesystem) readonly.
Dec 31 17:00:04 kernel: Freeing unused kernel memory: 116k freed
Dec 31 17:00:04 kernel: Please be patient, while OpenWrt loads ...
Dec 31 17:00:04 kernel: Algorithmics/MIPS FPU Emulator v1.5
Dec 31 17:00:04 kernel: mini_fo: using base directory: /
Dec 31 17:00:04 kernel: mini_fo: using storage directory: /jffs
Dec 31 17:00:06 kernel: vtss_core: module license '(c) Vitesse Semiconductor Inc.' taints kernel.
Dec 31 17:00:06 kernel: switch: 'Luton26' board detected
Dec 31 17:00:08 kernel: vtss_port: Loaded port module on board Luton26, type 5
Dec 31 17:00:08 kernel: nf_conntrack version 0.5.0 (2048 buckets, 8192 max)
Dec 31 17:00:09 system: Setting MAC address from flash configuration: EC:13:B2:81:03:72
Dec 31 17:00:09 kernel: i2c /dev entries driver
Dec 31 17:00:09 kernel: i2c_vcoreiii i2c_vcoreiii: i2c bus driver on IRQ 19
Dec 31 17:00:09 kernel: link state changed to 'up' on port 1
Dec 31 17:00:10 sysinit: Loading defaults
Dec 31 17:00:10 system: starting ntpclient
Dec 31 17:00:10 sysinit: Adding custom chains
Dec 31 17:00:11 sysinit: Loading zones
Dec 31 17:00:11 sysinit: Loading forwarding
Dec 31 17:00:11 sysinit: Loading redirects
Dec 31 17:00:11 sysinit: Loading rules
Dec 31 17:00:11 sysinit: Loading includes
Dec 31 17:00:11 admin: adding lan (eth0) to firewall zone lan
Dec 31 17:00:14 kernel: link state changed to 'down' on port 1
Dec 31 17:00:17 kernel: link state changed to 'up' on port 1
Dec 31 17:00:18 pinger: Ignoring port bounces because date is wrong
Dec 31 17:00:18 STP: set port 1 to discarding
Dec 31 17:00:19 STP: set port 1 to learning
Dec 31 17:00:19 STP: set port 1 to forwarding
Dec 31 17:00:19 kernel: eth0: no IPv6 routers present
Dec 31 17:00:19 sysinit: 1969-12-31 17:00:18: (log.c.97) server started
Dec 31 17:00:20 sysinit: /etc/rc.common: eval: line 13: uci_get: not found
Dec 31 17:00:21 dropbear[764]: Running in background
Dec 31 17:00:25 system: starting ntpclient
Dec 31 17:00:37 system: starting ntpclient
Dec 31 17:00:48 system: starting ntpclient
Dec 31 17:00:59 system: starting ntpclient
Dec 31 17:01:10 system: starting ntpclient
Dec 31 17:01:21 system: starting ntpclient
Dec 31 17:01:32 system: starting ntpclient
Dec 31 17:01:43 system: starting ntpclient
Dec 31 17:01:55 system: starting ntpclient
Dec 31 17:02:06 system: starting ntpclient
Dec 31 17:02:17 system: starting ntpclient
Dec 31 17:02:28 system: starting ntpclient
Dec 31 17:02:39 system: starting ntpclient
Dec 31 17:02:50 system: starting ntpclient
Dec 31 17:03:01 system: starting ntpclient
Dec 31 17:03:12 system: starting ntpclient
Dec 31 17:03:23 system: starting ntpclient
Dec 31 17:03:34 system: starting ntpclient
Dec 31 17:03:45 system: starting ntpclient
Dec 31 17:03:56 system: starting ntpclient
Dec 31 17:04:07 system: starting ntpclient
Dec 31 17:04:18 system: starting ntpclient
Dec 31 17:04:29 system: starting ntpclient
Dec 31 17:04:40 system: starting ntpclient
Dec 31 17:04:51 system: starting ntpclient
Dec 31 17:05:02 system: starting ntpclient
Dec 31 17:05:13 system: starting ntpclient
Dec 31 17:05:24 system: starting ntpclient
Dec 31 17:05:35 system: starting ntpclient
Dec 31 17:05:46 system: starting ntpclient
Dec 31 17:05:57 system: starting ntpclient
Dec 31 17:06:08 system: starting ntpclient
Dec 31 17:06:19 system: starting ntpclient
Dec 31 17:06:30 system: starting ntpclient
Dec 31 17:06:41 system: starting ntpclient
Dec 31 17:06:52 system: starting ntpclient
Dec 31 17:07:03 system: starting ntpclient
Dec 31 17:07:14 system: starting ntpclient
Dec 31 17:07:25 system: starting ntpclient
Dec 31 17:07:36 system: starting ntpclient
Dec 31 17:07:47 system: starting ntpclient
Dec 31 17:07:58 system: starting ntpclient
-LRL
I thought I'd try resetting the switch, but wanted to give you guys a heads up and the option to have me try something else first.
-LRL
