v1.3.0 & v1.3.1 & v1.3.2 FINAL bug reports and comments
Sun Aug 16, 2015 9:32 pm
Please post comments and reports bugs with v1.3.0 and v1.3.1 and v1.3.2 FINAL in this thread
v1.3.2 wrote:FIXES
- Changed input voltage safety check to only work on WS-12-DC model
----This routine could cause switches with AC or DC power supplies to turn off 48V POE if the input voltage sensors were damaged.
ENHANCEMENTS
- Added ability to emails log to arbitrary email address
- Added version selection for SNMP
v1.3.1 wrote:FIXES
- Fixed PoE Smart - POE Smart was applying POE then checking for cross shorts - Nuff said
- Added warnings when disabling HTTPS or SSH in GUI - Too many people were locking themselves out of the UI
- Made firmware upgrade dialog more user friendly- Too many people were complaining about this
- Fixed port Scheduled Port Bounce process getting restarted when correct time is set
- Fixed Ping Watchdog - The duration was not lasting the specified period of time
v1.3.0 wrote:
FIXES
- Fixed problem with SNMP reporting firmware version
- Fixed TFTP commands in CLI
- Fixed trunking VLAN ports with only the default VLAN configured
- Fixed problem when disabling IP address on VLANs
- Fixed reading 48VH current
- Fixed problem with loop protection between VLANs
- Improved getting time from NTP server
- Improved SFP modules compatibility and better recovery on faults
- Updated busybox for DHCP fixes
ENHANCEMENTS
- Added option to exclude syslog messages from NMS - Set on the Device/Configuration Tab
- Added support for 802.1ad aka QinQ aka Provider Bridging
- Added PoE Smart feature - POE Smart now only checks ports for cross shorts on cold boot and when applying POE to a port
- Added Port utilities menu (Cable Diagnostics, Port Bounce, Port Detail) on Ports tab
- Added button to re-run cable diagnostics
- Added option to require login on console port
- Added RADIUS login option
- Added "Last IP" to MAC table (ARP learning)
- Added "Allowed VLANs" to Trunk ports
- Added IGMP Snooping
- Added Iperf client and server
- Added support for WS-12-DC, WS-12-250-DC, WS-8-250-DC, AND OTHERS
- Added Power Priority for WS-12-250-DC
- Added 60 second timeout to SMTP configuration test
- Updated SNMP MIB with Netonix's Private Enterprise Number (46242)
- Updated SNMP MIB with DC model statistics
- Updated SNMP daemon with DC model statistics
- Improved performance of the GUI Log page
- Changed default MTU to 1528
KNOWN ISSUES
- Ubiquiti Discovery Protocol is still flaky
- Port Bounce is not powering down for 5 seconds - DO NOT RAPID FIRE PORT BOUNCE COULD DAMAGE EQUIPMENT
This issue also affects Ping Watchdog, Scheduled Port Bounce,
- POE SMart is broken, it applies power then tests for shorts....I KNOW RIGHT
Released 8/16/2015
adairw
Has thanked: 98 times
Been thanked: 132 times
Re: v1.3.0 FINAL bug reports and comments
Mon Aug 17, 2015 12:40 am
Just upgraded my 8-AC at home and am working on doing a couple 24 port switches.
Will advise if there are any issues.
designweb
Been thanked: 8 times
Mon Aug 17, 2015 1:05 pm
Thanks for an excellent product we have at least twenty variants across our network now and will probably never buy another toughswitch!!
It would be a nice touch if they worked with our Extreme compatible optics and had EDP :-)
Making Rural Internet a Reality
Mon Aug 17, 2015 1:12 pm
designweb wrote:Thanks for an excellent product we have at least twenty variants across our network now and will probably never buy another toughswitch!!
Can you provide model numbers.
What is EDP?
designweb
Mon Aug 17, 2015 2:28 pm
We have over twenty switches, in fact all of the AC versions and are keen to try some DC with wind and solar in our deep rural relays here in the UK.
Extreme Discovery Protocol apparently there are Linux packages that will add many discovery variants into the switches which just get better and better
WisTech
Has thanked: 9 times
Been thanked: 64 times
Mon Aug 17, 2015 2:38 pm
My 12AC at home upgraded from 1.2.4 to 1.3.0 with no issues and I have two VLANS running on it for midspanning.
anvilcom
Tue Aug 18, 2015 5:40 pm
Just upgraded AC12 from 1.2.4 to 1.3.0. No issues so far. It's not in production yet - still lab'ing it.
gerardor884
Tue Aug 18, 2015 6:48 pm
Please share the link once you get that up and running
I would appreciate it
v1.3.1 - RELEASED - CHANGE OVER FROM HERE DOWN
Tue Aug 18, 2015 10:29 pm
From here down in the thread please only report issues with v1.3.1 - NOT v1.3.0 - YOU SHOULD UPGRADE
designweb
Re: v1.3.0 & v1.3.1 FINAL bug reports and comments
Wed Aug 19, 2015 6:57 am
After upgrading 16 of my switches to 1.3.0, all was well until 12 hours ago when I lost a WS-24-400B which was supplying 1 mimosa, 1 24GHz HD airfibre, 1 5GHz airfibre and 3 powerbeams, the 48v line reverted to default off in the gui but the 24v stayed on, I will replace with 1.3.1 and see how it goes
Users browsing this forum: No registered users and 132 guests
