Bricked
garry@hsbnv.net - Member
Bricked
I lost power during an update. I can't get back into the switch. Shows no ethernet when plugged in. What is the process to get the switch back up and working?
Re: Bricked
Do you have a serial console cable?
MUST be a NULL modem cable.
If so hook it up and report what you see during a boot attempt
lokifirestar - Member
Re: Bricked
+M25PXX : Init device with JEDEC ID 0x202018.
Luton26 board detected (VSC7425 Rev. D).
== Executing boot script in 5.000 seconds - enter ^C to abort
RedBoot> fis load -d linux_recovery
Image loaded from 0x80100000-0x8035016c
RedBoot> go
Linux version 2.6.26.8 (dev@netonixdev) (gcc version 4.1.2) #6 Wed Sep 17 23:49:40 EDT 2014
Determined physical RAM map:
Zone PFN ranges:
Normal 0 -> 32768
0: 0 -> 32768
Writing ErrCtl register=80000400
Readback ErrCtl register=80000400
Memory: 126308k/131072k available (1854k kernel code, 4644k reserved, 404k data, 112k init, 0k highmem)
net_namespace: 324 bytes
TCP reno registered
JFFS2 version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
msgmni has been set to 246
io scheduler noop registered
console [ttyS0] enabled
No NAND device found!!!
mtd: partition "rootfs_recovery" set to be root filesystem
TCP cubic registered
Freeing unused kernel memory: 112k freed
- preinit -
Press CTRL-C for failsafe
mounting jffs2
switching to jffs2
- init -
Please press Enter to activate this console. vtss_core: module license '(c) Vitesse Semiconductor Inc.' taints kernel.
vtss_port: vtss_phy_reset failed, port_no: 12
vtss_port: vtss_phy_conf_set failed, port_no: 12
vtss_port: vtss_phy_reset failed, port_no: 13
vtss_port: vtss_phy_conf_set failed, port_no: 13
vtss_port: vtss_phy_reset failed, port_no: 14
vtss_port: vtss_phy_conf_set failed, port_no: 14
vtss_port: vtss_phy_reset failed, port_no: 15
vtss_port: vtss_phy_conf_set failed, port_no: 15
vtss_port: vtss_phy_reset failed, port_no: 16
vtss_port: vtss_phy_conf_set failed, port_no: 16
vtss_port: vtss_phy_reset failed, port_no: 17
vtss_port: vtss_phy_conf_set failed, port_no: 17
vtss_port: vtss_phy_reset failed, port_no: 18
vtss_port: vtss_phy_conf_set failed, port_no: 18
vtss_port: vtss_phy_reset failed, port_no: 19
vtss_port: vtss_phy_conf_set failed, port_no: 19
vtss_port: vtss_phy_reset failed, port_no: 20
vtss_port: vtss_phy_conf_set failed, port_no: 20
vtss_port: vtss_phy_reset failed, port_no: 21
vtss_port: vtss_phy_conf_set failed, port_no: 21
vtss_port: vtss_phy_reset failed, port_no: 22
vtss_port: vtss_phy_conf_set failed, port_no: 22
vtss_port: vtss_phy_reset failed, port_no: 23
vtss_port: vtss_phy_conf_set failed, port_no: 23
i2c /dev entries driver
mini_fo_lookup: ERROR, meta data corruption detected.
mini_fo_d_delete: negative dentry passed.
mini_fo_d_release: no private data.
RedBoot> go
Zone PFN ranges:
Normal 0 -> 32768
0: 0 -> 32768
TCP reno registered
- preinit -
mounting jffs2
switching to jffs2
- init -
Re: Bricked
That is the full output when connected using putty and a console cable. (I work with the OP)
Re: Bricked
lokifirestar wrote:That is the full output when connected using putty and a console cable. (I work with the OP)
OK so you need to do a TFTP recover as outlined in this Post viewtopic.php?f=17&t=1073
Re: Bricked
admin@Vball_SW_:/tmp# rx recovery.tar.gz
CCCCCCCCCCrx: too many errors; giving up
This is the error I get regardless of which step of the recovery I try.
Thank you for your help!
